Home > For Sale & Wanted > SVX grill, light surrounds, indicators, sidelight |
Drevil Member Since: 03 Jan 2022 Location: Berkshire Posts: 131 |
If you’re wondering….the above is this set up:
Click image to enlarge |
10th Mar 2023 7:44pm |
Landyash Member Since: 06 Feb 2011 Location: Nottinghamshire Posts: 286 |
Hi I have a few questions
Does it come with the headlight backing brackets or loom for the spotlights? Cheers Ash 👍🏻 |
12th Mar 2023 8:05pm |
Hi
Just what you see, so no additional brackets and no additional loom on the lights, albeit each has standard connectors so should be plug and play for a vehicle of the right age. Cheers |
12th Mar 2023 8:16pm |
Just triple checked the lights. The landrover stamped side lights have standard plugs for existing wiring to plug into.
The Hella stamped indicator units have a little loom from the unit to a standard plug, which then fits existing wiring. If the latter is what you meant by the loom, that’s there. |
12th Mar 2023 8:25pm |
Dropped the price, could do with these gone
17th Mar 2023 7:17pm |
scotsstag Member Since: 17 Jun 2012 Location: D+G Posts: 535 |
PM sent 04' 90 Td5 CSW..
19th Mar 2023 3:18am |
Sold
19th Mar 2023 3:45pm |
