![]() | Home > Td5 > 110 CSW - Bracket-hose brake & Clamp |
I think I know where you mean but a photo would help here. Do you mean the clamp on the chassis or on the axle?
ABS or non-ABS? Happy to pop out and take photos under Miffy ![]() |
doruk1981 Member Since: 15 Aug 2022 Location: Aargau Posts: 100 ![]() ![]() ![]() |
Yes the clamp on the chassis, the plastic parts on the axle also dusted off but they are identifiable on the diagrams ..
number 21 is mounted on the frame, then number 4 goes through the star shaped hole in 21. but I don't understand how item 20 should hold this thing together.. ![]() Click image to enlarge ![]() Click image to enlarge Td5 110 Station |
Ok yes I know where you are now.
So 4 gets pushed through 21 the there is a slot cut in to the end of 4 that 20 slots in to holding 4 in position. Does that help or would you like a photo? |
Although this is the front of a Disco the theory is the same.
I understand now - thanks a lot for the explanation and the picture.
the means how that comes together is such a LR thing ... simple but also kind of questionable ![]() |
