![]() | Home > Wheels & Tyres > anyone got 8x16 -32 offset wheels |
marsie Member Since: 18 Nov 2011 Location: sheffieldish Posts: 535 ![]() ![]() ![]() |
I have spotted a set of wheels on ebay but they are 8x16 -32 offset
will these fit without altering the arches? I plan on running 265 75 16 tyres on standard suspension but don't really want to be fitting extra width arches if I can help it and wondered if anyone had the same setup. don't want them to look too "Carlos Fandango" ![]() Thanks Paul 2000 90 TD5,galv chassis, d2 axles ,Bas remap , alisport intercooler , d2 transfer box , side windows-more to come-much more!! *GONE* 2004 110 TD5 Double cab. *GONE* 2010 110 2.4 XS station wagon |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20706 ![]() ![]() |
They shouldn’t protrude any further than the arches as above, if they do you need to fit wider arches to match so the new wider archers are qual to or a little wider than the new tyres. WeWillWin🇬🇧🇺🇸
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3393 ![]() ![]() |
Et -32 will stick way out, even with 265s on.
Et0 is about as far as you can go and stay legal with standard arches and 265s. Boosts are et33 so an et-32 will be 55mm further out on each side ![]() |
Can you share a link, Marsie? I'd hazard a guess that they're ET32 rather than -32. Darren
https://www.ebay.co.uk/itm/115001004878?mk...media=COPY 2000 90 TD5,galv chassis, d2 axles ,Bas remap , alisport intercooler , d2 transfer box , side windows-more to come-much more!! *GONE*
Have decided to stick to the boosts. Have fitted my 265s just need to get my spacers on now to get some steering lock back 2000 90 TD5,galv chassis, d2 axles ,Bas remap , alisport intercooler , d2 transfer box , side windows-more to come-much more!! *GONE*
Yep, those would definitely stick way out from standard arches!
Blimey, they really are -32
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074 ![]() ![]() |
-32 would be a bit too fandango even for me.
ET0 is a nice compromise IMO. |
I had 16x10 ET -32s on the 110 but was running 35 inch tyres and 50mm extended arches.
Would look a bit odd with just 265s on there.. ![]() |
