Home > General & Technical (L663) > Changing a set of wheels |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 434 |
Invest in a good 4T floor jack with a minimum height of 22" or higher.
Jacking points a fine and safe to use. The new floor jacks have a double plunger/cilinder and jack up very quickly. They also use a cardan coupling instead of gears which are proned to wear quickly. No Mud flaps for my 90.! ----------------------------------------- P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
3rd Mar 2023 8:53pm |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3425 |
This might be of use
https://topix.landrover.jlrext.com/topix/c...745447!0!5 24MY 90 D250 HSE, Tasman Blue |
3rd Mar 2023 9:10pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20591 |
I use a bottle jack, because a trolley jack canโt be used in all situations as it depends what the ground surface is. But if you have a solid floor garage or something like that then a trolley jack is faster and easier.
In an ideal world having both would be ideal, but as I said depends on situation. Each one has its different positives and negatives. Play Stupid Games, Win Stupid Prizes. Big Brother is Watching. ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
3rd Mar 2023 9:33pm |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1432 |
I have an exhaust jack for this.
3rd Mar 2023 10:11pm |
