Home > Puma (Tdci) > oil pressure light
chrisbowler
oil pressure light
Has anyone else noticed that the oil pressure light on a TDCi Defender takes a long time to go out - my car has less than 1400 miles on it and seems to take 5-8 seconds of running before the light goes out.
Any comments?
Chris Bowler
Post #94780 17th Oct 2011 9:14pm
TJ101
Re: oil pressure light
chrisbowler wrote:
Any comments?
Chris Bowler
Mine don't , nether has any of the previous ones Shocked California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #94785 17th Oct 2011 9:42pm
Bill
Ireland 2008 Defender 90 Puma 2.4 XS CSW Java Black
mine doesn't ether, but my abs light stays on for a bit, they told me it is normal. 08 Puma 90xs
BMW R1150R
KXF250
Keep On Truckin
Post #94787 17th Oct 2011 9:50pm
wslr
Check the oil or better still, change the oil and filter.
Post #94788 17th Oct 2011 9:50pm
warren
England 2009 Defender 90 Puma 2.4 HT Santorini Black
Mine usually goes out as soon as the engines started, the only time it didn't was when it needed to be topped up.
Post #94789 17th Oct 2011 9:52pm
ericvv
a good dealer would have informed you that the ABS light indeed has to stay on after starting until the car has moved and turned the wheels several times at a bit more than minimal speed as the system will be checking if the ABS sensors are functioning normally. Only after that process is completed and found to be ok, the ABS light goes out.
rgds, Eric
Post #94797 18th Oct 2011 4:34am
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
All lights out immediately, except for ABS which goes out once the 90 goes forward about 5 yds. Has been this way since new. Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #94799 18th Oct 2011 5:31am
MK
Not normal. Something is wrong= no oil pressure while engine is on Shocked : oil pump, low oil, sensor, valve. Light must turn off right away on any engine with an oil pump. Puma 110" SW
Post #94808 18th Oct 2011 7:22am
MK
Post #94809 18th Oct 2011 7:28am
Naks
Chris, I'd get that seen to asap!
Have you checked the oil level in the engine yet? It may just need a topup. --
Post #94817 18th Oct 2011 8:27am
RED-DOT
Relying on the oil light to warn you the level is low is plain stupid as damage will have been done on the move. It takes less time to dip the oil than it does to log-in here?
ABS light should go off at 5mph i think. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #94842 18th Oct 2011 11:05am
Lorryman100
I would get it into dealers as it could be something serious, partially blocked crankshaft breather/oil feeder pipe, oil pump fault/partially blocked feeder pipe etc. Or something minor like a faulty EOP sensor/harness plug. Low oil will throw on the EOP warning light as the lack of oil will reduce the engine pressure but I wouldn't rely on it as a oil level gauge as that is not what it is designed for.
If you have a dtc reader see if DTC P0520-15 is logged? If so the fault lies with the EOP sensor/harness.
Brian.
Post #94850 18th Oct 2011 11:40am
Happyoldgit
Check the oil level before you move it anywhere. Steve.
http://forums.lr4x4.com
Post #94858 18th Oct 2011 1:06pm
jst
pre 11MY ABS light goes out at 8kph.
post 11MY with Bosch ABS system light goes out after a predetermined time without moving IIRC. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #94876 18th Oct 2011 2:21pm
chrisbowler
Right - many thanks for all the comments - first TDCi I have had so nothing to compare with.
Have checked oil - it is at the right mark
Generally the oil light stays on as long as the glow plug light and sometimes goes out before the charge light but mostly after it.
Will be on the phone to the agent to get them to check it out.
Once again many thanks. - Have a short video so will try to post that tonight
Lorryman - thanks Have checks DTCs but all modules clear.
This could just be me being over cautius but I would expect the oil light to go out THE INSTANCE the engine turns!!!
Regards Chris Bowler
Post #94913 18th Oct 2011 6:08pm
