Home > Off Topic > Help please to identify this component (Bradex charge fast)
Defender SVX
United Kingdom 2008 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
Begging your help please to identify this component, my ancient Bradex fast charge 10 has finally given up presumably due to moisture in my shed Embarassed
As it was still a brilliant old piece of kit that despite my Ctek10 telling me many batteries were scrap I’ve managed to get them going by hooking this up to get some gentle charge in the completing a regeneration wit the Ctek (even managed to reverse charge one once Whistle)
Anyhow in a last ditch attempt to try and revive the old lump I’ve stripped the casing, measured the input to the transformer 240v and nothing at the rear and I’ve narrowed it down to component pictured as when bypassed the charger works fine again.
I’m asking the many knowledgeable people on here what the component is? Resistor, diode or micro capacitor etc and what value component should replace it. As I haven’t done any serious electronics since school 1996 Embarassed i think it’s best to ask before bypassing and leaving it on overnight in my shed Whistle
Many thanks in advance.
 Formerly mao99999
16 Focus RS Nitrous Blue.
11 FFRR TDV8 Vouge SE Black Black.
08 DEFENDER SVX SOFT TOP (SUPERB)
08 DEFENDER 110 DCPU Stornoway grey (Overland Exploration Unit)
05 Fiesta ST 150 Van
04 Jaguar XKR 4.2 Supercharged V8
02 DEFENDER 90 TD5 (next years soft top project)
95 DEFENDER 110 CSW 300 TDi Phoenix black
95 DEFENDER 90 HT Monti Carlo blue COUNTY 300 TDi
67 109" SERIES 2a TUNED 200 TDI
64 DAVID BROWN 990 rat look
55 86" SERIES 1
Post #983981 28th Feb 2023 4:30pm
Dinnu
I am thinking its a thermal fuse. But strange that is so far from the winding. Generally it is fitted as close to the winding as possible, so in case there is a prolonged overload, the fuse will melt and prevent a fire hazard. Of course unless you pulled it out of its correct position.
Check the temperature rating. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #983983 28th Feb 2023 4:49pm
Defender SVX
No that’s exactly the way I found it the live goes into into the first spade then goes through the component onto the coil, all I did was change the live to the spade after the component to bypass it and the charger worked.
A fuse sounds correct as there is no continuity between the component terminals. There is writing on the component but is generally faded Confused also the soldering around the transformer is dubious but as this charger is made in GB in the 80s it’s probably from factory Rolling with laughter Formerly mao99999
55 86" SERIES 1
Post #983984 28th Feb 2023 5:04pm
Dinnu
Kind of weird installation then.
I am not telling you to do same, but I did bypass thermal fuses in the past and got away with it every time. I guess manufacturers install extra protection due to liability.
You may install an inline current fuse and have that blow incase there is a short circuit. Thats what my old charger has and works for me. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #983985 28th Feb 2023 5:12pm
Defender SVX
Definitely worth a try, fortunately in the UK we have fuses in the plug 3amp on this so should be fine Shocked many thanks for your help Thumbs Up Formerly mao99999
55 86" SERIES 1
Post #983986 28th Feb 2023 5:16pm
Dinnu
Be careful, as the 3A fuse in the plug is protecting the primary side of the transformer. 3A on a 240V is equivalent to approx 700W, or 50A on the secondary at 14V (assuming no losses).
Looking at that winding, I doubt if the secondary is able to handle 50A.
I would look at the rated charging current and wire an inline fuse on the low voltage side. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #983988 28th Feb 2023 6:04pm
That would be my first conclusion too. It looks very similar to one I replaced recently on an oil-filled mains electric radiator.
Post #983989 28th Feb 2023 6:19pm
Defender SVX
Again I bow my head to your knowledge and also to the oracle (blackwolf) Bow down the component/thermal fuse is direct off the hot wire, ie live wire from the 3 pin plug after the main fuse then on to the 240v side of the transformer should I fit a inline fuse instead of the failed component? Formerly mao99999
55 86" SERIES 1
Post #983992 28th Feb 2023 6:35pm
Dinnu
Yes, a thermal fuse is generally on the supply, so if the unit (transformer in this case) heats up too much, it cuts off the supply.
If the thermal fuse is on the secondary side of the transformer, it would only cut off the load, but the primary would still have 240V, and if there is a fault in the primary, then it can still cause a fire hazard. That would be bad design.
A thermal fuse and a current fuse work very differently, and personally I think a thermal fuse on a charger is an overkill. Thermal fuses are better suited on heating elements, like using a kettle without water, or heaters that can accidentally be covered and overheat.
But I would still want to protect over current on the secondary in case for example you accidentally short out the alligator clips, or connect reverse polarity. So a spade fuse (like what you will find in the fuse box of your Defender) in line on the red alligator clip would be the best solution. Google 'Inline fuse holder'. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #983994 28th Feb 2023 7:00pm
Defender SVX
Great stuff Thumbs Up I’ve got plenty of blade fuse holders, I’m fairly electronic savvy both ac and dc (I’ve just re soldered a 2011 Vauxhall fuse box) but had no idea what this component had to do with the unit.
I can remember when I was a young boy maybe 10 or something I bought a second hand 1-10 scale radio control car (also had the series one) and the only charger that came with it was a small transformer that was screwed to a piece of plywood Shocked it became my school project to make a vacuum formed cover for it as my hand would “buzz/tingle” when I touched it Whistle my “cover” was a A+ project and when shown to my dad the charger and the cover were destroyed and a new one bought Whistle Formerly mao99999
55 86" SERIES 1
Post #983998 28th Feb 2023 7:23pm
