Home > General & Technical (L663) > Sarek Automotive is working on a lockable rear diff
Naks
https://www.facebook.com/X5offroad/posts/p...aNBDrxQoDl
Post #981737 8th Feb 2023 10:01am
Naks
He just posted some more details:
"Almost have the working prototype for a selectable air locker for folks without the factory rear TOD rear locker. Final product will be a Billet case half to replace the factory differential case half and an ARB carrier unit. This will give the ability to manually lock the rear differential independent of the terrain response system settings or in case of failsafe operation. The ARB differential is also much stronger than a stock differential. The ARB has 4 spider gears vs stock with 2 spider gears with a single pin. Billet housing will include a larger carrier bearing and reinforced bearing race support. Case half will have all provisions to connect air line without the need to drill and tap." --
Post #981751 8th Feb 2023 11:54am
Mark1107
United States
I sold him my open differential and helped a little. This will be a game changer vs spending 6k on retrofitting the oem rear locking differential. Ralf is the man! 2022 Defender Trek Competition 110 collectors edition!
2020 Defender 110 P400 Full Explorer Pack 7 Seater HSE Fuji White(sold)
2020 SVO Range Rover L405 Full Size Spectral Blue Chromaflair
2014 Range Rover L405 Autobiography Full Size Aintree Green
2014 Dodge Viper GTS Stryker Green
Post #984426 5th Mar 2023 7:05am
lightning
At what level of off-road use does a locking rear differential become necessary?
l never used the locking centre differential on my 2005 Defender in the nine years l owned it, and l didn't even have the ABS/TC
The new one in standard specification seems fairly unstoppable in standard specification (no locking rear differential)
There must obviously be times when it's an advantage otherwise someone wouldn't be going to the trouble of developing an aftermarket one.
Post #984450 5th Mar 2023 10:49am
Naks
^ mate, if you're not locking your CDL, you're not off-roading Whistle
The OEM rear diff lock comes into use more often than you think, mostly to aid traction/reduce strain on the drivetrain. It also comes into play on-road, especially in the twisties. Of course, not applicable to this aftermarket one. --
Post #984452 5th Mar 2023 11:24am
DSC-off
^ Laughing
....lThere must obviously be times when it's an advantage otherwise someone wouldn't be going to the trouble of developing an aftermarket one.
Excuse the example vehicles, but this type of thing requires difflocks on a high traction surface. Note, no spinning tyres when wheels are lifted in the air or climbing steps.
On a low traction surface, like mud or sand, they can be very useful too.
Post #984546 6th Mar 2023 12:14am
mse
Ive wondered about this, the rear locking diff is what £1500k from LR and there is a loom £500? and then the CCF file changes to say its fitted.
Plus fitting, which is probably a pain
What else is needed to get it to £6k Mike
Post #984577 6th Mar 2023 12:15pm
lightning
More useful than l thought! Too late for me though l doubt l will go far enough off road to need one.
Post #984619 6th Mar 2023 6:04pm
DSC-off
It's never too late... you know you want to. Whistle
Post #984621 6th Mar 2023 6:18pm
Mark1107
United States
Wrong. The rear locking differential in 2023 is about 2500 lbs, plus you have the core charge, plus the differential module is 700 lbs, plus you need to wire both to the rear cargo fusebox and the wire them to the BCM in the passenger footwell plus you need the larger half shaft which is 3-400 lbs plus you need to hire an automotive electrical engineer to install all of this as well. Oh yeah locking differential fluid is 80 lbs per quart. Plus CCF programming. Installation labor is in the range of 1500-3000 as well.
So its north of 6000 USD to add the locking differential.
But you could try buying used parts but there arent many locking differentials on ebay. Also there are two different differentials depending on engine size and drive train.
Now compare all of that mate to Ralfs Sarek simple solution.
I'm the only person in the world who added the locking differential OEM parts to a P400 2020 Defender. Nobody else has done it.
Post #984721 7th Mar 2023 5:48pm
mse
Im not disputing the additional parts i hadnt thought about larger half shafts and a car module - i assumed it used the main one.
Wiring is a few looms it would sound rather than one i identified. I suppose thats just a ball ache though
But i did, until recently, have full access to parts and the diff in the UK wasnt that much £.
CCF programming - well actually its only enabling, is easy there are a few people in the UK that can do it
Ive changed a few diffs so thats not a big deal Mike
Post #984792 8th Mar 2023 7:59am
XplusYplusZ
Speaking with the LR Experience guys, they quietly told me they didn't need the rear locking diff. I guess since the electronic traction systems are so smart, you'll get through pretty much any obstacle* without it. It probably wouldn't be as calm and controllable, but it'll do the job.
(*Unless you're climbing cliff faces like the wrangler in the clip above!)
Post #984813 8th Mar 2023 11:54am
Retroanaconda
The thing I love about the diff is that it’s proactive. It can lock up progressively depending on the mode, and avoids tyres scrabbling for grip. The Terrain Response is incredibly good and responds very quickly, certainly better than older systems, but it’s still reactive and so it’s not as smooth a drive.
In summary if ordering new I would always spec it if you want to use the car off road, but if buying second hand it wouldn’t be a deal breaker.
Post #984818 8th Mar 2023 12:25pm
