Home > Td5 > Insulation replacement for acoustic engine cover?
BCdefender
Canada 1999 Defender 110 Td5 CSW Orkney Grey
Mice have chewed through the insulation of the acoustic engine cover...
Any advice on what product to get that would be an upgrade to what was in there? I assume it would have to heat resistant etc..
Thanks a lot. 1999 Defender 110
2003 P38
2007 RR SC
"And that's why it needs to be celebrated, because when the Defender goes we'll have lost this pointer to where we came from, and we're really going to miss it."
My build thread: http://www.defender2.net/forum/topic47750.html
Post #981413 5th Feb 2023 8:35pm
htb2
Wales
Just buy another off fleabay, plenty on there around the £20 mark.
I have 3 of them 1 on the 110 and 2 spares.
Post #981421 5th Feb 2023 9:09pm
4RF RDS
You can use spray foam insulation…. Wrap the motor top (valve cover) with cling wrap, spray the foam where you need it on the cover, put the cover in place… it'll dry quickly. Remove. Trim the excess off and use it.
Or… find a used one on the bay of flea!
Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #981596 7th Feb 2023 4:07am
The Gribbin
United Kingdom 2001 Defender 90 Td5 HT Auto Caledonian Blue
Re: Insulation replacement for acoustic engine cover?
Thanks a lot.
I replaced mine with a lead lined blanket from Noise Killer... tucks down the back, and seems to deaden the noise pretty well.
Post #983463 23rd Feb 2023 8:23pm
1NRO
https://www.nkgroup.co.uk/product/vehicle-...-blankets/
Might be worth speaking to this company.
Post #983466 23rd Feb 2023 8:35pm
