Home > Technical > Alarm ECA location |
Landowner Member Since: 06 Jan 2023 Location: Somerset Posts: 76 |
Hi, can anyone tell me where the alarm ECA (a10s?) is located in a 2012 red puma? I want to unplug the ultrasonic sensors, more trouble than they are worth.
Thanks |
4th Feb 2023 12:47pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 |
Pull the ultrasonic sensor out of the headlining (clips in) and unplug at the sensor.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
4th Feb 2023 1:11pm |
Thanks Steve, I wasn’t sure if there would be a connector up there.
4th Feb 2023 1:27pm |
Or….. The manual says “ By locking the vehicle with the key in the driver's door rather than using the remote RF handset.” I tried this (left the passenger door unlocked - no central lock-in), locked the car using driver’s door and the opened the passenger door. No alarm. Think I’ll just unplug the sensors and use the fob |
4th Feb 2023 1:29pm |
I though perhaps that it was just on the central locking versions. No worries, just disconnected the sensors easy once someone points it out!
4th Feb 2023 5:29pm |
