![]() | Home > Puma (Tdci) > Hand brake light: flicker party |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 672 ![]() ![]() ![]() |
It is also the brake fluid level warning light.
enfield_dinosaur Member Since: 14 Jun 2015 Location: Tertius orbis Posts: 120 ![]() ![]() |
Oh - thanks!
Looks like a trip to the workshop, albeit not under its own power. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17667 ![]() ![]() ![]() |
It's probably nothing to worry about, just top up the brake fluid.
As the pads wear the fluid level in the reservoir drops a little. The sensor in the cap is very sensitive and when you go downhill or brake the fluid moves to the front of the reservoir away from the sensor, and of course braking lowers it more. On my Def to prevent the effect you describe I need to keep the fluid level at the bottom of the reservoir neck, well above the "min" mark. |
kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074 ![]() ![]() |
Mine did that, the contacts in then old switch were goosed. New one solved it.
Crofter Member Since: 19 Feb 2015 Location: Peterhead Posts: 169 ![]() ![]() ![]() |
I had corroded brake pipe which caused that problem. Check the level. |
