![]() | Home > Technical > V8 Works steering box mods |
kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074 ![]() ![]() |
I could be wrong but I heard on the grape vine they used the kit from Blackbird Industries
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 496 ![]() ![]() |
Dont know I thought BB came about after the Works setup?
Notyalc Member Since: 27 Jul 2018 Location: Northumberland Posts: 165 ![]() ![]() ![]() |
Steering column is a hybrid, top half defender bottom half P38; that way you get the correct UJ at each end. I assume that was the question?
Box is mounted outside the chassis which requires a new bracket and panhard brace (not the panhard rod). Cannot help with the inner wing, but it would be obvious when the box was fitted i would say. |
Yes I already have the Blackbird kit but wanted to see what sort of effort JLR had made of the column and inner wheel arch.
