![]() | Home > Td5 > Electric windows |
Jordan Member Since: 08 Jan 2022 Location: Leicestershire Posts: 49 ![]() ![]() ![]() |
I have a 2000 TD5 90, has anyone installed a universal electric window kit?
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 905 ![]() ![]() ![]() |
Hi
Is the loom pre installed and all you do is connect the switch and motors? Jim |
There is nothing, it is 2000 TD5 so I was looking at a universal kit.
TVR Tommy Member Since: 26 Nov 2013 Location: Bucks Posts: 183 ![]() ![]() ![]() |
It might be worth you buying some old electric window doors and pulling off all the parts needed. Then you could get a disco 1/2 electric window switches and wire it up.
Just seen you're fitting to a 2000 so you'll want to go universal switches. Disco switches fit in post 2002 dash |
Mac2505 Member Since: 01 Jul 2023 Location: Buckinghamshire Posts: 3 ![]() ![]() |
Hi
I bought masai electric window conversion kit. Just 9ne question, it says connect to ignition +15. Where exactly do i connect the red cable? |
