Home > Maintenance & Modifications > Billet Windscreen Blocks Recommendation
rallysteve
Morning all,
One of the things on the shopping list is a new pair of billet windscreen blocks. I don't want anything fancy looking so was thinking of the Britpart Whistle ones which actually seem good value. I have read that the anodizing is quite bad for fading on them however.
Does anyone have any recommendations for others to look at?
Cheers,
Post #979317 23rd Jan 2023 9:37am
AMBxx
I've had Gore black anodized on since the first once decayed. After 5 years they still look good as new.
However, my Defender is kept in a garage, so no extended UV exposure and I've never used traffic film remover. Others may have different experience.
Post #979322 23rd Jan 2023 10:57am
Avelingporter
you can always paint to match over the anodised. Its what I did and still look like new.
Post #979327 23rd Jan 2023 11:20am
kenzle8a
buy the cheapest ones you can, shot blast them and paint them with graphene primer 1st
Post #979343 23rd Jan 2023 12:49pm
markb110
https://www.ebay.co.uk/itm/295165236201?mk...media=COPY
I’ve got these in my watch list on eBay.
The seller uses a different finish to the anodised offerings so you don’t need a special wash to preserve them, basically fit and forget.
Take a look and see what you think. Thumbs Up
Post #979348 23rd Jan 2023 1:08pm
AMBxx
>>> Formulated to withstand temperatures of up to 1800°F
Good for that journey to the sun!!
Post #979370 23rd Jan 2023 2:59pm
markb110
Apparently the product advisor is someone called Greta Iffyboatrace...... Whistle
Post #979435 23rd Jan 2023 8:04pm
Screbble
Might also be worth looking into?
https://www.powerfuluk.com/vehicles/land-r...ender.html
Obviously there are different colours!
They also have near standard looking replacement blocks.
I have no experience of these - I removed mine, prepared them, etch primed and top coated them some years back. One is still great and the other is showing signs of oxidisation… Whistle
Post #979442 23rd Jan 2023 8:20pm
I'd second this. The key though, is to ensure that they're painted all over, which I think is what causes the problems with the existing.
You can see how I treated mine here:
https://www.defender2.net/forum/post784740.html#784740
 Darren
Post #979520 24th Jan 2023 10:59am
discomog
I'm not sure about the window blocks from SC Engineering fitted with o'rings rather than gaskets. Is it possible to over tighten them, compressing the o'rings and then resulting in metal to metal contact between the block and frame thereby causing more corrosion problem? Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #979535 24th Jan 2023 12:52pm
I'd be concerned about that, too. I made full size rubber gaskets for mine. Darren
Post #979603 24th Jan 2023 5:52pm
Linds Hanson
The hinged type by Design and Development look really cool and last well
Post #979707 25th Jan 2023 11:37am
stephan123
+1 for Gore!
Post #979753 25th Jan 2023 4:31pm
rallysteve
Thanks all, I think the Gore ones look the best bet. Will go for plain anodised and get them painted when/if they fade.
Cheers,
Post #979755 25th Jan 2023 4:49pm
ChrisDefender
Another + for the GORE window blocks, superb bit of kit. I have been waiting for the door hinges for years but they just never seem to be in stock Sad
Post #979770 25th Jan 2023 6:25pm
