Home > Maintenance & Modifications > Leaking bolt in bulkhead window bit
Simonwood
Hi
Every time it rains water seeps thru the bulkhead window bolt.
Should I just unbolt, and reseal with some silicone ?
Thoughts ?
Post #979287 22nd Jan 2023 10:13pm
Ianh
Do you mean one of the bolts that goes into the windscreen blocks / brackets ?
If so a new gasket would help https://www.powerfuluk.com/vehicles/land-r...ender.html
Post #979301 23rd Jan 2023 12:51am
Simonwood
Than you
Thanks Ian. Just ordered from your link provided.
Owe you a beer Smile
Post #979358 23rd Jan 2023 12:55pm
jim4244
England 2007 Defender 90 Puma 2.4 CSW Zermatt Silver
We’re you getting a puddle of water in the footwell?
Jim
Post #979386 23rd Jan 2023 3:45pm
Simonwood
Yes that’s correct.
A fair amount. Traced it to the bolt and think the new gaskets above will help. Worse case it’s a window seal? I believe there is a gasket between the frames.
Post #979415 23rd Jan 2023 5:53pm
Ianh
For the seal... try “Captain Tolley’s Creeping Crack Cure”, I know it sounds like a solution to a medical issue, and always makes me smile when I read the name, but it does find and stop annoying leaks.
https://captaintolley.com/product-info/
Downside is the surfaces need to be dry....but that’s what hairdryers are for Very Happy
Post #979428 23rd Jan 2023 6:25pm
markb110
Its available on Amazon so next day delivery if a Prime member if that helps
Post #979431 23rd Jan 2023 6:54pm
Screbble
Plus one for this - and I too smile when I read the product name (but not when I apply it…) Rolling with laughter
Also worth sealing the backing plate on the inside as you are removing the bolts for the window blocks anyway. I used clear RTV sealant on the face against the body (obviously!) Thumbs Up
Post #979445 23rd Jan 2023 7:24pm
Screbble
Simonwood wrote:
Yes that’s correct.
My footwell puddle was attributed to a hairline crack where the gutter meets the roof above the drivers door. It tracked along the top of the door and down the hinges side. Cured by good old Captain Tolley Thumbs Up
Post #979446 23rd Jan 2023 7:27pm
