Home > Puma (Tdci) > Blowby 2.4 TDCI |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17338 |
Depending on the age of the engine, it could be one of those with the defective PCJs in which case you can't rule out bore damage, I'm afraid.
22nd Jan 2023 10:21am |
audi1boy Member Since: 11 Dec 2020 Location: Somerset Posts: 24 |
Hi Blackwolf what is the PCJ?
Thanks again |
22nd Jan 2023 10:28am |
Piston Cooling Jet?
22nd Jan 2023 10:29am |
Another quick question.....
How can I do a Pressure test on the engine that would ommit the injector seals? If I pressure test it im guessing any leak could either be the injector seals or the rings with no way of differentiating? I guess putting some soapy liquid around the injectors and turning over by hand may tell me if its the seals and not the rings? |
22nd Jan 2023 10:32am |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3407 |
Correct, PCJ is the abbreviation for Piston Cooling Jets.
Can do a leak test through the injector holes? If the valves are ok, then all leakage is through the piston rings. If leaking through the valves, you would hear it from intake or exhaust manifolds, but the latter will not cause blow by. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
22nd Jan 2023 10:57am |
Hi Dinnu,
Thank for the info. What I was unsure of is if i do a compression test by removing the glow plugs, if it is low is there any way of telling if its leaking past the rings or the injector seals? I will try tomorrow to remove the rocker cover and turn the engine over manually to see if there is any leak coming past the injectors. Fingers crossed there is. Thanks |
22nd Jan 2023 2:47pm |
Yes, as other have replied PCJ = piston cooling jet. The early 2.4 TDCi had an issue with hysteresis with the pressure relieving valves in the PCJs which meant that in the event of excessive oil pressure (such as starting with a cold engine) the PCJs would close but not reopen properly. The result of this was catastrophic bore wear in a very short time. There was a service instruction for this (replacement engine to be fitted) but as was (and remains) typical for LR and the classic Defender it was a "secret" instruction - you had to complain about your destroyed engine in order for anything to be done. After about three years LR withdrew the instruction on the theory that all the engines that were likely to suffer from the problem would have done so, so no further repairs would be entertained. In practice, as a gesture of "goodwill" LR has agreed to discount the labour on the fitment of a new engine if you can prove that this problem killed your own one, but the downside is that it has to be a new engine supplied by and fitted by a main dealer. Inevitably this is many times more expensive than a new engine from another source fitted by a good independent. |
22nd Jan 2023 5:07pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2411 |
All 2.4 and 2.2 Tdci engines I have seen, from brand new to used ones up to 200Kkm breath heavily when removing the oil cap. Puma 110" SW
23rd Jan 2023 10:08am |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 361 |
Okay, that's a valid point, but in order to make it comparable, one should name a overpressure-value at this point, otherwise it's all subjective, unfortunately.
24th Jan 2023 9:36am |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2292 |
There are some injector seal before and after videos in this thread https://www.defender2.net/forum/topic74338.html
You could use this as a basis to compare how bad yours is chuffing. There is a crankcase ventilation valve as shown here https://www.defender2.net/forum/topic79296.html > 110 XS Double Cab |
24th Jan 2023 10:33am |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4646 |
Yep our 2.4 had it's engine replaced when six years old due to this. Land Rover paid 75%. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
27th Jan 2023 11:54pm |
