![]() | Home > Technical > Fuel gauge accuracy….. or not. |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 541 ![]() ![]() |
I reckon on my 110 when light comes on I have 45-50 miles left in the tank so 9-13 L.
Thought tank capacity was around the 80-85 L on 110, should be the same on a 130. |
Def not linear, If I brim the tank, I get around 100 miles till it drops to the topmost mark on the gauge. Another 100 miles till the 1/2 full mark and about 150 miles till it runs out. This pulling a loaded 3.5t trailer most of the time and 1/2 ton of gear in the back of the Hicap.
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5815 ![]() ![]() |
3 Defenders and they have all been different on the gauge. Current one does 100m off the gauge, then starts to read on the gauge with about 100 miles per half gauge. I just fill up at 300 miles. I’ve run out once in this one as it doesn’t last long in low section.
