ABS Light how to turn it off? (I don't have an ABS Module)
Hi All,
I have a fitted TD5 to my 90 with a full extras harness (including ABS), but I do not have the ABS module installed. I would like to switch off permanently the LED. I tried removing the fuses and relays and nothing happens. Also tried to switch it off through the ECU but couldn't. Is there any other options to switch it off?
Thanks in advance.
12th Jan 2023 12:27pm
Martin Site Admin
On your warning light panel 20 way plug, connect pin 10 to pin 6 with a wire loop.
You may also need to do the same for the handbrake/fluid level lamp. Connect pin 9 to pin 13 with a wire loop.
This is the FACE view of the plug, the wires would come into the back on this view.
Click image to enlarge 1988 90 Td5 NAS soft top
2015 D90 XS SW
