![]() | Home > Technical > Puma odd power drop |
Jpu121265 Member Since: 13 Aug 2022 Location: Normandie Posts: 8 ![]() ![]() |
I've had another look today. There is a definite loss of boost, mainly when coasting in 5th/6th gear, time varies, sometimes it comes back on its own, sometimes it comes back when going down through the gears.
I've checked the actuator harness, seems fine although it has almost rubbed through the conduit so will address that. The actuator rod is free (it was sticking a little on its highest, a bit of WD40 and there's no resistance at all up or down). Live data, when it happens, everything sort of drops as though it's demanded by driver, fuel pressure, air flow, just descends with speed. Have just changed the MAF and MAP for known good ones, still happens. Minded to think it's the actuator solenoid, have taken the lid off it and everything seems fine with it, a bit of dust so have cleaned it out, will see if that makes a difference. Still no DTC's. Do these solenoids fail? |
Boost pipes all seem fine, going to check intercooler next, but I would have expected a DTC there.
Have taken a video and, while stationary, the actuator moves as expected when revving. Can tell it's a boost drop as you feel it pick back up, and when it happens, you coast in neutral and it labours up to around 3k, there's no 'pep' from the turbo. I'll see if I can find a second hand actuator locally to try and see if this improves things. Runs and drives fine apart from randomly coming off boost! |
For anyone interested, I have found out what it is, it might help someone else. The 'brain' reckons it is overheating, it is pressurising the coolant system, not sure whether it was doing it before but now I can see the gauge go to red (up to the top) and drop back down after a while, bleed screw full of air, and the coolant cap (gently undoing it) is full of gas as well. Hopefully just a faulty EGR cooler, I believe the head gaskets are pretty robust on these.
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4746 ![]() ![]() |
Yes there is an in built safety feature that will shut down the engine if it starts heading into overheat territory. Happened to our 2008 Puma. Turned out to be a leaking in the cooling system caused by a loose hose clamp. If you have no leaks check when your coolant was changed last. 1982 88" 2.25 diesel
