![]() | Home > Technical > LT230 road speed transducer Miles v KM |
I am almost 100% positive the LT230 sensor is the same for mile and km with the conversion being done in-gauge or ECU. Seem to recall that the signal goes to the gauge first then to the ECU.
Fit and test against a GPS would be your easiest route. |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 324 ![]() ![]() ![]() |
The transfer box transducer will be the same regardless of odometers reading miles or km.
So no need to source or fit a new speedo drive into the transfer box if all you want to do is change the speedo head to a metric one. The transducer provides a pulse to the speedo (4100 pulses per mile of memory serves me) which it converts to a speed reading. The speedo then doubles this pulse rate and sends it to the ECU so the ECU can do all sorts of clever speed:engine RPM related maths. |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 497 ![]() ![]() |
All use the same transducer, only variation is the drive gear for different tyre sizes
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1154 ![]() ![]() ![]() |
Thanks all. Makes sense. Will swap out as is and report back. Should be quick and simple.
