![]() | Home > Puma (Tdci) > Heated Windscreen Switch = No Light |
KISSMYAURA Member Since: 13 Jan 2018 Location: KENT Posts: 45 ![]() ![]() ![]() |
GLR10
![]() ![]() Click image to enlarge Try testing or swapping this out they are not expensive |
you should get power to relay, to make it click then on to the timer, so check fuses first!
nocker65 Member Since: 05 Mar 2024 Location: England Posts: 1 ![]() ![]() ![]() |
Can I jump on the thread as I am having the same problem? All fuses are ok The relay clicks when pressing the switch, but no light comes on. The screen does not work at all |
