![]() | Home > Maintenance & Modifications > Ventilation servicing, air direction control, cabin filter |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2252 ![]() ![]() |
This is worth a read and has some good links to vendors. https://www.defender2.net/forum/topic82461...bin+filter
A key issue is sealing the joint between the ducting and heater blower, else dust will be drawn in after the filter via engine bay. The oct4x4 one https://otc4x4.pl/products looks better as you can fit a snow cowl over it. |
