![]() | Home > Modifications & Maintenance (L663) > Land Rover Defender Arctic Trucks AT35 |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2667 ![]() ![]() ![]() |
Land Rover Defender Arctic Trucks AT35: https://www.autoevolution.com/news/land-ro...07282.html
"...Enter Iceland-based Arctic Trucks, or better said the off-road specialist’s Russian subsidiary. Based on the family-sized 110 with the mild-hybrid sixer under the hood, the AT35 in the featured clip doesn’t break a sweat on snowy trails in sub-zero weather. As implied, the main difference over the standard model comes in the guise of tires. As opposed to 255/50 by 20s (make that 30.1 inches for the outer diameter), the Land Rover Defender Arctic Trucks AT35 flaunts 315/60 by 20s (34.9 inches). The 12.4-inch-wide tires are complemented by double-spoke wheels finished in dark gray. Arctic Trucks Russia further sweetens the deal with spacers for the front and rear suspension, updated geometry fore and aft, wheel-arch extensions at every corner of the luxury-oriented sport utility vehicle, anti-corrosion coating, branded mudguards, Artic Trucks bodyside decals, a recalibrated speedometer, and a torque wrench. This fellow also boasts a ground clearance of 360 millimeters (14.1 inches) as opposed to 290 millimeters (11.4 inches) fully stock. In terms of approach and departure angles, the Russian subsidiary lists 39.1 and 40.1 degrees with coil springs or 38 and 40 degrees with air suspension. Curb weight estimate? That would be anything between 2,541 and 2,598 kilograms (5,602 to 5,728 pounds), and the turning radius is a little worse as well at 7.5 meters (24.6 feet) compared to 6.5 meters (21.3 feet) unmodified. Arctic Trucks Russia didn’t publish any pricing details for the AT35 package, but don’t expect these modifications to come cheap. ..." ![]() Click image to enlarge -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Sepp Member Since: 05 Oct 2020 Location: Bavaria Posts: 114 ![]() ![]() |
From Russia?
Never ever will buy anything from those bloody ![]() |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1468 ![]() ![]() |
Same. Murdering scum!
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6158 ![]() ![]() ![]() |
I don't suppose AT are actually invading Ukraine themselves though.... |
nowrxo Member Since: 10 Sep 2015 Location: None Posts: 79 ![]() ![]() |
Presumably they have corporation tax in Russia, and the employees pay income tax. So the proceeds will help pay the costs of the war.
RFT Member Since: 13 Nov 2010 Location: Cheshire Posts: 688 ![]() ![]() ![]() |
Parent company is actually Icelandic but this truck seems to come from their Russian subsidiary 130 Puma HCPU with an Artica 240LR Demountable Camper
