Home > Maintenance & Modifications > Transfer Housing Impacting Seat Box
Adyonline
United Kingdom 1987 Defender 90 300 Tdi HT Chawton White
Hi All,
When I purchased my 1987 2.5 Defender 90 the previous owner had just completed an upgrade to an R380 + 300TDI.
I've just pulled out and replaced the seat unit whilst changing the battery box and noticed the transfer housing is rubbing up against the seat box, pushing it out by about 15mm - see picture
Has anyone else encountered this issue?
Also unable to fit screws in to the the gearbox tunnel;
Post #975868 28th Dec 2022 1:27pm
rustandoil
Check engine and gearbox mounts as a first step
Post #975874 28th Dec 2022 2:09pm
Adyonline
Thanks Rust, the mounts are located centrally.
Post #975875 28th Dec 2022 2:19pm
geobloke
Re: Transfer Housing Impacting Seat Box
During the engine and gearbox upgrade did the PO replace the seat box, transmission tunnel and Bulkhead?
They are different between the LT77 era and R380 era vehicles, the latter is wider to accommodate the gearbox and bell housing. Best photos I can find, but you get the idea...
R380
LT77
Post #975876 28th Dec 2022 2:28pm
Adyonline
Geo - Thank you, mine has a 'modified' LT77 tunnel (with a hammer!).
I think I see the problem, the R380 tunnel has the wider part connecting the seat unit, and I guess the seat unit is cut out to allow for the transfer housing which is currently contacting my seat unit.
Anyone know who sells new gearbox tunnels?
Post #975878 28th Dec 2022 2:53pm
Hufflepuff
I got one recently on EBAY, its just a fibreglass/plastic type affair on the td5.
The corresponding seatbox front panel is available for the various gearbox options on YRM, but prepare to wince at the price.
https://yrmit.co.uk/product/seat-box-front...eries-2-3/ 2005 Td5 90 XS
1989 V8 110 CSW
Post #975880 28th Dec 2022 3:41pm
Adyonline
Thanks Huffle, do you know if the handbrake will require relocating? as you can see from my first picture in the OP the handbrake is located directly above the section of the transfer housing that is interfering with the seat box.
Yup, £69 for the seat box adapter plate, plus another £98 for the bulkhead panel is starting to make this an expensive bit of work, particularly when you look at around £150 for the replacement s/h tunnel
Post #975895 28th Dec 2022 7:30pm
Adyonline
Well, the order is in anyway....
Post #975901 28th Dec 2022 8:00pm
Hufflepuff
Sorry I don't know on the hand brake location. I actually wonder how 'defined' the position was on this, or did it happen to be where the worker of the day happened to wave his drill bit when making the hole for it?
I have built a complete new seat box from the YRM panels, and was planning to move the handbrake location to the top surface between the seat and cubby box with a Disco style lever. However they seem to be less generally available than I had hoped and have not managed to locate one yet (although in fairness I haven't looked very hard). 2005 Td5 90 XS
1989 V8 110 CSW
Post #976013 29th Dec 2022 10:11pm
Adyonline
Thanks huffle...
I received the parts and have started the conversion.... But does anyone know how far the tunnel should be from the edge of the seat unit as placing the adapter plate in the same location as the handbrake holes does mean it still fouls the transfer housing ??? - see last pic...
The old tunnel housing:
Starting to cut away the old tunnel flange;
Old flange removed;
New (and S/H) parts;
New template still interferes with transfer housing if handbrake holes are aligned;
Post #977000 7th Jan 2023 3:57pm
TexasRover
Could it be that the gearbox mounts are different and it shifted the whole gearbox/transfer case to one side?
I am actually breaking a 110 Td5 RHD and can take pictures of the brackets etc as I just removed the gearbox and engine. I am in France so shipping parts over could be a little expensive but sure if you need some..
Post #977010 7th Jan 2023 6:07pm
TexasRover
When I measure the RH side if the tunnel at the seatbox to the outside edge of the floor (not the outer sill plate) i get 520mm.
Tomorrow with daylight I can give you more datum points from the RHD 110 standing outside. Possibly the handbrake mounting has been shifted for the Td5 setup
Post #977020 7th Jan 2023 7:00pm
TexasRover
Looks like the handbrake mounting is further outboard
measurement if from the top of the seatbox (corner)
Post #977059 8th Jan 2023 10:24am
Adyonline
Texas - Thank you so much that's really helpful! Thumbs Up
With your help I've managed to make some progress.....
First I fitted the new bulkhead template;
Then a quick mockup with the tunnel in place;
Having marked the edge of flange I cut back the seat box to full width;
The new position of the template;
And now drilling the holes in the template ready for the rivets and hand brake;
Post #977094 8th Jan 2023 2:07pm
TexasRover
Perfect, looks like you are almost there. Let me know if you need more help.
Post #977098 8th Jan 2023 2:14pm
