Home > For Sale & Wanted > MINT 2006 90 pick up
Landy nut
United Kingdom 2006 Defender 90 Td5 PU Epsom Green
For genuine reason I am selling my mint condition 2006 td5 90 3-seat pickup in Belize green.
It has 41k on the clock and comes with a FSH. I have a credit with my local LR dealership for a free 48k service (worth about £500) so this will be done prior to the new owner taking receipt of the vehicle.
It comes on a set of 5 brand new Michelin Latitude Cross tyres on white genuine factory fit wheels. These are the latest LR genuine fitment tyre.
Everything on this vehicle is completely genuine as factory with the only change being upgraded speakers and head unit. It has a full set of as new genuine LR rubber mats too including a rear tub liner. It comes with a towpack (unused) and an Ifor Williams canopy which I have very carefully fully waterproofed (no big piles of silicon here!) including the door so you can guarantee a dry cab even in a thunderstorm. There are no odd noises or rattles at all and there are (amazingly) no water leaks. It also comes fitted with a pair of Extreme 4x4 rear armoured corners (6mm galvanised and powder coated) and I also have a genuine LR fitment Brownchurch bull bar for it should the new owner wish. These are the same as fitted to the Camel Trophy vehicles. I have fitted it with a flat plywood floor in the back to give me storage of my odds n sods underneath and a flat area on top to put shopping etc. This floor is fully removable and not drilled or attached to the vehicle and sits on top of the rubber tub liner.
I have very recently done a complete fluid change on the vehicle using high spec fluids, to include: oil and both filters (genuine), coolant drain, flush and redo, drain and redo of both gearbox and transferbox, greasing of propshafts, draining and redo of both diff fluids, complete bleed of full brake system and clutch system and I have also replaced the clutch master cylinder and starter motor - both with genuine parts. It also has a brand new Bilstein steering damper fitted and a new genuine drop arm ball joint. I am somewhat OCD on maintenance and do a full service myself every 6 months in between dealer servicing.
Do not be confused by sales people who say their vehicle is mint condition only for you to find blemishes, small paint dings or signs of wear.....this vehicle is nothing like that. It truely is one of a kind condition. I wash and wax it regularly and am fastidious about mechanical work so you will not find a better vehicle. It drives and looks as new, with everything feeling "tight" and is mint underneath (washed regularly) with no signs of age at all. This is not and has never been a commercially owned or worked vehicle and not been abused at all. I purely use it for plodding around with the wife, but need a vehicle with more seats now. I am genuinely gutted to see it go as I had hoped to keep it for years so hope it finds a good new owner soon.
Any test drive is welcome (from genuine interest) and you will not find a better one. Price is £11k.
Post #93779 11th Oct 2011 7:36pm
Green Machine
Any pics? Thumbs Up 2005 Td5 | 90 Station Wagon | Tonga Green
Post #93781 11th Oct 2011 8:02pm
