Home > Wheels & Tyres (L663) > Urban WX-2 Wheels fitting questions.
David007
Has anyone fitted a set of Urban 22" WX-2 wheels, I’ve not physically seen these yet fitted to a car and was a bit concerned about how far they stick out, If my calculations are correct with the offset the fronts are moved out by 20mm and the rears 30mm which seems quite a lot, so does this push the wheels out beyond the arches? Also I noted that the wheels can be supplied with new TPMS sensors, do these need coding or anything to the car to work. Thanks
Post #974620 14th Dec 2022 7:30am
