Home > Maintenance & Modifications > Torque Wrench - recommended or reviews
roche1800
Does anyone have any advice a good torque wrench, best value for money? Cheers
Post #974238 11th Dec 2022 1:11pm
callumgodfrey
I use a Halfords 1/2 inch and it's very good (I use it every day at work) and passes calibration every 6 months.
Link: https://www.halfords.com/tools/hand-tools/...=undefined
Post #974249 11th Dec 2022 3:15pm
LR90XS2011
Ditto
I have a Halfords one, came in a good box and when checked on work Torque meter is spot on for its intended range, DEFENDER 90 TDCI XS,
Post #974253 11th Dec 2022 3:43pm
rustandoil
A lot of industry use Norbar
https://www.norbar.com/
Post #974257 11th Dec 2022 4:26pm
Depends on range, budget, and a few other factors, but classic Britool is hard if not impossible to beat.
Post #974258 11th Dec 2022 4:38pm
kenzle8a
The Halfords pro ones are hard to beat, I’ve had mine for 12 years, i have the 0-60 3/8th and 60-200 1/2
Post #974259 11th Dec 2022 4:40pm
Another vote for the Halfords one. I've had mine for about 4-5 years and it's great for the price. Darren
Post #974260 11th Dec 2022 4:53pm
Ianh
I’m pretty sure norbar make Halfords advanced range.
I have two norbar pro wrenches, covering a full range of torque settings from 10 -340nm. They are also dual scale , Newton meters and foot pounds.
A helpful list on using and storing a torque wrench.
The ten things you should know about your torque wrench - https://www.norbar.com/News-Events/Blog/Ar...que-wrench
Post #974261 11th Dec 2022 4:53pm
nitram17
Halford do source their torque wrenches from Norbar(i think) i cannot fault them...Teng are also good but at the cheap end Draper would be sufficient for the DIY er..I have never ever had a problem with a Draper product....
Post #974282 11th Dec 2022 6:14pm
Draper for me, perfect for occasional home use never had a problem. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #974283 11th Dec 2022 6:16pm
rallysteve
Not sure if it is still the case but the Halfords pro ones used to be made by Norbar i believe.
Post #974284 11th Dec 2022 6:24pm
I can remember being warned off Norbar when I started serious spannering because they were not very good at all, but that was around 1970 and since then there has been a major transformation for the better.
I didn't realise until just now that Norbar is now a subsidiary of Snap On tools.
Post #974302 11th Dec 2022 8:19pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
What is this 'torque wrench' that you speak of?
Post #974313 11th Dec 2022 10:26pm
Dinnu
Maybe is irrespective of brand (or perhaps the good ones have better internals), it is a good idea to release the pressure from the spring (set torque setting to 0) when it needs to be stored away. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #974320 12th Dec 2022 4:50am
MartinK
I've had two TENG ones for about 20 years! Both work well. One for smaller stuff (up to 20nm IIRC) and one for bigger stuff (approx 19 - 130 nm). Been very reliable. Would recommend.
Looks like these:
https://www.tengtools.com/products/torque-...h-20-110nm Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #974324 12th Dec 2022 7:30am
