Home > General & Technical (L663) > Analogue dash
lightning
Analogue dash
On the basic analogue dashboard can you change the main display in the centre or is it fixed on current speed?
l assume you can't, had a look at the online owners manual and can't find anything. l know you can change what's in the the small display at the top but l can't read that without my glasses !!
Post #973408 4th Dec 2022 7:17pm
LR Nuts
Post #973409 4th Dec 2022 7:35pm
J77
You can set it to this, photo is from an evoque but defender is the same, can also be set to show the map.
 24MY 90 D250 HSE, Tasman Blue
Post #973412 4th Dec 2022 8:21pm
lightning
I had a look and in "Display" l don't have an option for "layout" so l guess l am stuck on "current speed"
in the display
Post #973451 5th Dec 2022 11:19am
Farmerben
United Kingdom 2015 Defender 90 Puma 2.2 HT Keswick Green
Press the circle on the left hand set of buttons on the steering wheel. That brings up a menu to select what you want to show on the display panel. https://instagram.com/bentheoandrews
Post #973455 5th Dec 2022 11:39am
lightning
Thank you
Look at that, that's another thing l've learnt today!!
Post #973463 5th Dec 2022 1:21pm
