Home > Td5 > ECU Woes |
andy2111 Member Since: 17 Oct 2021 Location: Kent Posts: 365 |
Worth speaking to these people https://www.ecutesting.com/product-catalog...anagement/
They will do a test on your current unit first which is £45 and if there is a fault and you ask them to repair it the fee is waived |
4th Dec 2022 5:43pm |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 881 |
Thanks, had mine collected today Nice that they offer a warranty.
8th Dec 2022 6:04pm |
Let us know how you get on.
I have some intermittent issues and the ECU is one potential cause and so I have considered sending it to the same people to get tested |
9th Dec 2022 8:32am |
Well the ecu returned from ecutesting and it powered the dash lights which was more than it did before. But then cranked and didnt start. Swapped back to my spare and it fired up straight away.
Ecu testing collected it again they called me and said their head engineer tested it and everything was fine but theyll disable the immobiliser in case that was causing an issue. Received it back today, crank and no start. It did throw a fault code once of 'injector # peak charge long' on all injectors # being the injector number. I double checked the usual culprits injector plug etc all fine. Plugged in my spare ecu and it fired up straight away. Ive emailed them tonight and ill see what i hear back from them. Kind of just want my money back and to buy another ecu at this rate. |
5th Jan 2023 10:05pm |
Super7 Member Since: 05 Feb 2014 Location: South Bucks. Posts: 132 |
I had exactly the same problem with this company. My ECU was sent to them 4 (yes really!) times, and each time they said they had tested it and it worked perfectly. Even after my ECU was supposedly fully rebuilt by them it didn’t work, and yet my spare ECU would start the engine first time and run without any fault codes.
I did eventually get most of my money back but it wasn’t easy... '99 TD5 Defender 90 '52 Series 1 80" '99 Caterham 7 |
6th Jan 2023 8:57am |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2102 |
Crumbs…
I’ve just had a reconditioned ABS unit delivered from ECU Testing. I hope I don’t have any issues as it’s been a pain the bottom of a job so far already Their customer service was first class - but obviously the proof of the pudding will be if the unit actually works! |
7th Jan 2023 10:27am |
Well it went and came back a 3rd time after being 'rebuilt'. Still didnt work, have sent it back to them for good now and should be getting a refund.
17th Jan 2023 10:11pm |
Sorry to hear that - hope you get the full refund 👍
18th Jan 2023 6:33pm |
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 789 |
Only one person I would recommend to do any testing or work on TD5 ECUs is Dan from Storm Tuning.
Hes a decent guy and will give you an honest appraisal about whether it's going to be cost effective to repair, but also usually holds a reasonable stock of tested ECUs in stock for those that are not cost effective to repair. He has tested and repaired ECUs and also supplied replacements too for my customers. Dan Matthews, Storm Tuning +447711069434 Best Regards Chris[/i] |
18th Jan 2023 7:58pm |
