![]() | Home > General & Technical (L663) > Driving modes? |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1207 ![]() ![]() |
see link
https://www.ownerinfo.landrover.com/model/...261_en_GBR then scroll down to 'Driving Programs' |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2926 ![]() ![]() |
Thank you for the information
It doesn't look like there's anything to change how the vehicle responds on the road, such as "sport" or "eco" mode For instance l test drove a Volvo and in "eco" it changed up sooner and there was less performance, whereas in "Sport" it hung onto the gears longer before changing up. |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5059 ![]() ![]() ![]() |
Sport is dove via the gear stick
Eco hit terrain response and knock it back 1 for eco Mike |
ls that the S +/- on the left of the gear selector?
Reason l am asking is, whatever mode it's in at the moment, if you are driving at a steady speed and hit the gas, nothing happens for about three seconds and then it surges forward and feels like someone has gone into the back of you it's so sudden. |
eco mode explained https://www.ownerinfo.landrover.com/docume...c/G2398149 |
WizzardPrang Member Since: 05 Nov 2020 Location: Hertfordshire Posts: 161 ![]() ![]() |
"S" on the gear shift = sport mode (knock it to the left), holds on to gears longer. Also allows you to shift up or down manually, which is also useful off-road to make it hold 1st, etc. Current vehicle: 2020 Defender 110S
Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2 Insta: wizzardprang |
reminds me of the old Freelander 1 auto 'sport edition' around 2004 plate
![]() Yes the L663 is the same. |
Great thank you l will give that a go.
ls it better to be in this mode when towing a caravan, or just leave it in Auto? |
MHE15 Member Since: 25 Mar 2022 Location: Midlands Posts: 32 ![]() ![]() |
![]() Click image to enlarge Leave it in auto. The best tow car I have driven! |
