Home > Faults & Fixes (L663) > Windscreen - - -
gilesn
Windscreen - - -
About a month & 800 miles of ownership - have a 6 inch long crack in my windscreen.
Fortunatly its very low down on the passenger side - just up from where the wiper parks.
OK - yes I will need to get it fixed - hopefully at low cost under my insurance (need to check the small print on that)
But I am wondering if anyone has any experience of windscreen fitting companies -
I believe the screen is bonded in, it has a heating element in it & it has all of the camera, (sign recognition) wiper sensor & lighting sensor fixed to it.
I want to make sure I have someone do the replacement that knows what they are doing - not to sure if any of this stuff will need re-calibrating?
Thanks -
Post #972430 26th Nov 2022 9:50am
Moo
Ukraine
Wasn't this an issue on early cars?
Post #972434 26th Nov 2022 10:31am
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
Re: Windscreen - - -
gilesn wrote:
Ab I want to make sure I have someone do the replacement that knows what they are doing - not to sure if any of this stuff will need re-calibrating?
s -
Your ADAS ( Advanced Driver Assistance System) will need re calibrating with a new screen, a reputable glass company should include calibration in the replacement process
https://transparencyautoglass.com/blog/wha...libration/ Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #972436 26th Nov 2022 10:53am
Retroanaconda
The windscreen company will either be able to recalibrate it, or of not then a dealer can do it. These systems are very common now so places are used to doing them.
I had my screen replaced by Autoglass at 4,000 miles and they did it no bother, including calibration. I had them use a genuine screen as the car was only a few months old at the time.
Post #972467 26th Nov 2022 4:24pm
lightning
l ordered the solar reflective windscreen as this is supposed to be less prone to the cracking issue, but this option now seems to have disappeared from the online configurator.
Post #972612 27th Nov 2022 5:27pm
gilesn
Update -
Sort of booked in now - I say sort of as I have to wait till the windscreen is availble.
Hopefully that will be in the next couple of weeks.
Will have to be fitted at a 'fitting' center - as yes the camera system will need to be re-calibrated.
Did a little more research in to this - yes a millimetre of error at the winscreen will equal a far bigger error 100 to 200 meters up the road.
Hope the windscreen stays on the current leadtime as with the colder weather now everytime i put the heater the cracks in the screen grow - they are now over 12 inches long!!
Post #973166 2nd Dec 2022 9:14am
gilesn
Done - fitted -
Turned up at the fitting garage.
Replacement screen was ready on a stand.
Was told it would take approx 2 hours - depending on the glue/resin to cure & the 'calibration'
Went back in under 2 hours - all done fitted, cured & calibrated.
Have driven it home - lane depatured worked (as normal/before), spped limit signs were recognoised as before.
Will check the headlight assist tomorrow morning.
Only thing I was 'dissapointed' with was its not a genuine LR windscreen.
I asked why not - as my appointment was delayed to get the like for like replacement but the fuitting guys said they get that alot.
People are told they will get an OEM replacement - then when they turn up its a non OEM windscreen.
With the 2 big (over 14 inch long) cracks I had - i needed to hget it repalced.
Was amazed how thin the screen is - didn't measure it but i don't think it was over 2mm
Post #974558 13th Dec 2022 1:54pm
lightning
One positive.
Maybe the OEM windscreen will be less prone to cracking in the future. l've read of a few where the screen has cracked.
l remember this happened years ago when the Ford Sierra first came out...if you parked with one front wheel on a curb the screen could fracture!
l doubt this is the reason for the Defender screens failing, maybe it's because the glass is so thin.
Post #974914 16th Dec 2022 7:01pm
