Home > Puma (Tdci) > Auxillary power on 13Pin Trailer Fuse. |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2165 |
Generally the Aux power is from a direct feed off the battery as it isn't part of the std fit trailer wiring (7P from factory)
Most likely it will be separately fused directly off the battery?? |
16th Nov 2022 9:15pm |
BenB8man Member Since: 22 Mar 2017 Location: Norfolk Posts: 429 |
If its the factory 13pin wiring kit, they'll be a feed from the battery to a relay under the passenger seat. The relay is triggered from an ignition live behind the dash.
Worth checking whats under the seat and if you can find that relay. |
16th Nov 2022 10:10pm |
Polarismd Member Since: 13 Feb 2022 Location: Leicestershire Posts: 62 |
Hi, I don't have any obvious connection to the battery.
I will just have to check all the fuses one by one. Thanks anyhow. Chris |
16th Nov 2022 10:11pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6610 |
Is this the permanent (pin 9) or ignition feed (pin 10)?
The ignition feed is not fused as part of the vehicle loom, it is a retrofitted fuse and relay block in the battery box. The permanent feed is from fuse 2 under the RH seat on a 2.4 Puma. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
16th Nov 2022 10:22pm |
Hi
Thanks, that's very helpful. It's the permanent feed. I will check that one. Regards. Chris |
16th Nov 2022 10:27pm |
