Home > Technical > 2.4 2011 power loss, I know another thread.
Page 1 of 3 123>
jst
Grateful for any views please.
Initial loss of power after a period of mixed driving.
First two instances it happened were off a specific roundabout 16 miles into a journey. Power drops under acceleration.
Power loss and max revs of 2000rpm.
After a few seconds, 2 or so power comes back.
Now happening more frequently when into a longer journey.
Power loss initially occurring after being on a heavier power demand, ie pulling off a roundabout, after a hill climb.
Now seems to occur at any point and takes longer to sort. 30 to 50 seconds
I have tried the following to help restore power quicker.
1. Blipping accelerator, whilst scan gauge shows load and gph changes it has no impact on fuel delivery.
2. Cycling ignition makes no difference.
3. Multiple clutch presses no difference
4. Swapped in known working MAF no difference.
5. Closed loop bypass clutch switch no difference
6. When power has been lost if dip clutch and blip accelerator there is no increase in fuel delivery ie no rev change, it drops to a lumpy idle.
7. If turn ignition off and restart when there is lack of power there is lumpy idle for few seconds.
Only bas tool and scan gauge available. No fault codes shown.
Engine temp is normal 74 to 85 degrees when it occurs.
VCV changed 5k miles ago
Vehicle used almost daily, filter changed 3k miles ago
As of today occurred 5 or 6 times 20 miles into a journey.
As of today you can feel a power drop about to happen when on lower accelerator demand with a slight hesitation from the vehicle.
Initially keeping accelerator pedal all the way down when it occurs seemed to restore power quicker.
Yet to test if leaving the vehicle for a period after occurrence will help.
Makes max boost pressures. No intercooler or turbo linkage concerns or changes turbo wires.
What do we think?
Vcv? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #970858 12th Nov 2022 8:53am
Sticky turbo vanes or actuator, on mine the actuator sticking caused such behaviour.
Though does put on a DTC but not always.
Effectively causes limp mode.
VCV going usually fuses stalking at low speed, rough cold idle and reduced top end power I.E. in 6th.
EGR can cause some strange issues, as can the clutch switch though the latter usually is gear change associated. TheThunder Rolls🇬🇧🇺🇸
Post #970877 12th Nov 2022 11:59am
jst
Egr gone
Clutch switch bypassed and still does it.
Turbo was initial thought but it is boosting and boost pressure bchanges as expected. Actuator is free moving no resistance.
Fault occurs at intermittent times on boost, off boost too.
Idle is erratic if cycle ignition as fault occurring. Ie fueling is not correct at that moment.
Also gives no throttle response when fault occurring as in although throttle position read out shows input is applied there is no corresponding change in actually fueling from what I can see.
Vanes is on agenda to look at. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #970887 12th Nov 2022 3:02pm
Grenadier
Maybe your VCV has failed earlier than you’d wish for? It does sound very VCVy. If that’s a word? Identical problems to mine before my swap. The fact they’re known to fail frequently, clearly makes them fallible. And therefore no reason why one should last 50,000k as much as 5,000k…. Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #970903 12th Nov 2022 5:37pm
Check the turbo hose hasn’t been rubbing on the steering column too, a common one but not easy to notice. TheThunder Rolls🇬🇧🇺🇸
Post #970917 12th Nov 2022 7:29pm
jst
Hoses are good externally.
Other thoughts I had were pressuring fuel tank, maybe pressure relief valve being faulty? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #970932 12th Nov 2022 11:06pm
Sounds very much like VCV to me.
Post #970944 13th Nov 2022 7:21am
The annoying part it seems about the VCV’s is some may last years, my last one was about 12yrs old!
Others seem to not last a few years.
But equally, are we ending up with unknown contaminated fuel with water in?
I know for a fact that when mine gave up the ghost it was just after I used an independent fuel station that I’ve never used before.
I’m damn sure there was water in the fuel, it was too coincidental. TheThunder Rolls🇬🇧🇺🇸
Post #970963 13th Nov 2022 12:49pm
Water in the fuel will kill a VCV in seconds.
Post #970965 13th Nov 2022 12:59pm
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
This is exactly what I experienced and had recently changed the VCV .
After a lot of wasted time and money, I eventually exchanged the VCV and the problems vanished.
Both were from PF Jones https://www.instagram.com/hustynminepark/
Post #970974 13th Nov 2022 3:04pm
PF Jones was where I got my replacement from too, no programming needed and been right as rain ever since.
It was surprising what power came back too!
But yes, I think water in fuel is what does it. Even a little, and the coincidence of the fuel station and it happening within a day or two… TheThunder Rolls🇬🇧🇺🇸
Post #970985 13th Nov 2022 4:26pm
jst
That sounds promising.
So your first replacement vcv gave up soon after fitting and another then fitted solved it? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #971027 13th Nov 2022 8:34pm
hank
Recently had similar sounding symptoms and spend nearly a grand replacing all sorts. My VCV was less than a year old so I assumed it could not be that.
In the end I replaced the VCV again and normal running was restored > 110 XS Double Cab
Post #971031 13th Nov 2022 8:42pm
Bluericky
Hi JST
Yes it was probably in for 6 months or so. I also changed the fuel filter at the same time as that seemed logical.
The symptoms have gone but now I have another gremlin where my puma has started cutting out when idling . Then sounds a little rough on restart for a second or two.
I’m not sure if it’s related .
Anyhow the VCV swap eliminated the intermittent lack of power and lack of throttle response https://www.instagram.com/hustynminepark/
Post #971042 13th Nov 2022 10:05pm
jst
Vcv ordered! Can't wait to change that again! Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #971126 14th Nov 2022 4:45pm
Page 1 of 3 123>
