![]() | Home > General & Technical (L663) > Door seal/gutter - surprise! |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2926 ![]() ![]() |
Yes that's a common issue, you'll most likely find that the water is leaking in via the Alpine Window seals and runs along inside the roof.
Then, if you happen to park in a downhill slope or on a road camber etc the water pours in through the top corner of the door on to your leg, or down the inside of the door. Check your Alpine Window seals It took me literally years to find that out after fitting new door seals, new bulkhead seals, windscreen seal, and roof seal, to try and stop it. So you could say l suffered the pain, expense (and wet jeans) so you don't have to. Oh, and when you fit new Alpine Window seals, make the joint along the top NOT along the bottom of the window. Then seal the joint properly Use ONLY genuine LR seals, the alternatives are steaming piles of horse manure. And how do l know that? Yep, another £40 wasted |
The OP is talking about a New Defender but it's amusing that they've carried over these sorts of features
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
XplusYplusZ Member Since: 16 Aug 2021 Location: UK Posts: 507 ![]() |
Correct - sorry, should have clarified. And very amusing once you know.. |
Is this for the old or new Defender? My problem is in a New one.. |
Offending gutter:
![]() Click image to enlarge It looks like the gutter doesn't catch all water, and instead some water leaks through to the second seal. It's not clear if the water on the inside of the door has leaked past the second seal, or is just remnants from where I've opened the door.. ![]() Click image to enlarge |
Well, l misread the first post and assumed it was the old Defender
But you can't have a Defender without at least one random water leak. As already said, it's nice to see Land Rover have carried on the tradition with the new one. |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6120 ![]() ![]() ![]() |
I'm sure some Britpart rigid seals will stop that
