Home > Puma (Tdci) > Creaking body
Jed
United Kingdom 2007 Defender 110 Puma 2.4 DCPU Cairns Blue
Creaking body
Hi all, I have a 07 pickup puma. I have a lot of creaks coming from the drivers footwell when moving over uneven ground and also with the driver side door, with the door shut and driving on uneven roads if I put my fingers in the gap between the door frame and body above the window the gap gets smaller and wider as if the door is moving in it’s closed position.
Thanks Guys
Post #970551 9th Nov 2022 8:27pm
kenzle8a
I’d be more worried if they didn’t creek as it would mean all the bits had fallen off. It’s just part of the way defenders are built
Post #970555 9th Nov 2022 9:02pm
The doors are the source of many creaking noises and this can be hugely mitigated by adjusting the catches correctly and applying Gummi-Pflege to the seals.
Post #970561 9th Nov 2022 9:34pm
barbel jim
Or replacing worn door hinged
Post #970563 9th Nov 2022 9:36pm
Grenadier
I used to have similar creaking from the footwell, addressed by tightening up all the footwell footplate bolts. 10min job.
I notice you’ve got a DC. I have wondered if they suffer from more body flex than a SW or even a 90. Mine creaks a lot. Head round a hairpin bend and it’s pretty obvious. And then (as now) when winter arrives, even more creaking as everything shrinks. Just put the music on louder or focus on the other noises.. Rolling with laughter Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #970589 10th Nov 2022 7:46am
Jed
Thanks for the reply’s everyone
Post #970591 10th Nov 2022 8:00am
kenzle8a
My double cab gets creakier once it gets below 10c
The ifor canopy doesn’t help either…
Post #970593 10th Nov 2022 8:12am
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
My 90 2011 Puma is the same… I’m quite used to it now Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #970610 10th Nov 2022 10:07am
They do creak more when it is cold, and when it is frozen it can be even worse. I have found that adjusting the doors to fit properly and keeping the seals clean and dressed (the Gummi-Pflege stuff) really helps. It also tends to reduce the likelihood of the doors freezing shut as the seals shed the water better.
I did also have to tighten up most of the bolts which hold the body together on mine not long after I bought it, those holding the roof panel to the B-posts, and those along the cab rear panel (it's a double cab) were on the whole actually loose. That stopped a lot of body noise. The build quality of Defenders, certainly in the last decade of production, really was quite exceptional - and not in a good way.
There comes a point when cranking up the volume is the best remedy and gives you peace of mind.
(Edited because the fingers were typing different words to those the brain was directing!)
Post #970627 10th Nov 2022 12:59pm
Jed
Thanks again for the replys
Post #970628 10th Nov 2022 1:04pm
ossrider
United Kingdom 2010 Defender 110 Puma 2.4 HT Tamar Blue
I've got what sounds exactly the same 'creak' from under the driver's foot well also. Has appeared in the last week or so. I've had the vehicle 18 months or so now without it but sounds like it may be connected to the recent drop in temps? I've had a liberal spray of wd40 today as I got sick of hearing it but will check all bolts in the area. Thanks for bringing up the topic Jed and appreciate everyone's comments so far.
Post #973221 2nd Dec 2022 4:15pm
miker
All the structural rigidity of the newspaper wrapped around yesterdays Chips Laughing Laughing
Post #973293 3rd Dec 2022 8:27am
ossrider
Update which may help others.
The creaking has been getting worse over the last few weeks, so much so that the 'turn the radio up' was no longer working. So, I finally managed to get underneath this afternoon and have a poke around.
Long story short, it would seem to be the back edge of driver foot plate where it meets the seat box. Bolts were tight but actually loosening them a little at this stage has almost cured it. I will revisit and investigate further in due course but I am so relieved to hopefully rid the noise that was starting to really wind me up!
Post #980066 27th Jan 2023 5:30pm
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
My 110 station wagon also has a creaking from the footwells. Where do I find the bolts that need tightening? Inside the footwell or outside underneath? Is there a torque setting or just nip them up?
Post #980496 30th Jan 2023 1:54pm
Cragster69
Scotland 2007 Defender 110 Puma 2.4 CSW Cairns Blue
Depending on your rubber mat and carpet and sound deadening configuration, the bolts are normally into captive nut plates or the plastic raw plug type and should be fairly straightforward to tighten if they are lose. Not sure what to advise if everything is tight though?
Mine were all rusted and I had to cut them out and replace them, that was why I changed them not because they were creaking. Craig.
“Don't believe everything you read on the internet.” ― Abraham Lincoln
www.scotgrc.co.uk
Post #980518 30th Jan 2023 4:32pm
