Home > In Car Electronics > Heated windscreen melted connector |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 320 |
That's unusual, you don't say which side has melted but I assume driver's side (power) rather than passenger side (earth).
You could crimp on a new connector, make sure the copper in the cable is nice and bright, not corroded and green as that could be the cause of your issue. It can get quite damp in that area and the HFS does draw quite a substantial current. There's a couple of good videos on Youtube showing you how to clean corroded copper wire with white vinegar, salt and baking soda. If I was you I'd consider looking at the connectors on both side of the circuit. In essence, cut back damaged cable, clean copper strands if required, crimp on new connector, try HFS again when fitted. |
8th Nov 2022 4:35pm |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1081 |
I never needed my heated windscreen, but nevertheless I tried it out right after buying the Landy.
It's the "bathtub curve" https://en.wikipedia.org/wiki/Bathtub_curve I know this doesn't help practically but maybe mentally |
8th Nov 2022 6:09pm |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1423 |
It’s the passenger side. Cut wire back and crimped on new connector.all good. Couldn’t see any damage, the. It out section was a strange orange colour, probably because it got so hot.
Just at a bit of a loss as why? Was working fine. |
8th Nov 2022 6:28pm |
