Home > Puma (Tdci) > Is it easy to replace a B post? |
caribcat Member Since: 11 Jun 2009 Location: Anglesey Posts: 97 |
2013 110 Utility: I have a box of matches sized bit of rot below the rear right hand side passenger door hinge. I can take to a body repair shop obviously but suspect it will just come back. Is it a relatively painless job to pop in another B post or do you have to lift the roof and get into some serious deconstruction of the body shell? Has any had similar rot?
26th Oct 2022 12:27pm |
kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074 |
Doors off and it unbolts from the top, all the welding is at the bottom.
26th Oct 2022 1:33pm |
