Home > Maintenance & Modifications > Cubby box sizes |
Yes, those factory fitted with the Alpine sub are shorter than standard ones. Darren
19th Oct 2022 7:28pm |
Sussex110 Member Since: 18 Jun 2021 Location: Sussex Posts: 21 |
Perfect. Thanks Darren, now just need to find one!
20th Oct 2022 9:02am |
balmybaldwin Member Since: 17 Apr 2021 Location: Surrey Posts: 192 |
Can you not put it under the second row seats?
22nd Oct 2022 11:43pm |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 620 |
https://www.ebay.co.uk/itm/403711583496?mk...media=COPY
Top left is a genuine subwoofer cubby, you can identify them by the side section of the box where it transitions from the cup holder to the front face of the box - the factory fitted subwoofer cubbys have a slightly protruding lip. You just have to buy all six to get it! |
23rd Oct 2022 1:26am |
I've been reading the various threads about other locations and have been looking in to below the rear seats
Excellent info on how to spot one Oldowner!! I'd poured over photos and not noticed that, thanks |
24th Oct 2022 3:46pm |
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 |
It's probably also worth noting that the factory subwoofer is noticeably thicker than the aftermarket subwoofer. The reason being that the aftermarket Alpine sub has the crossover and its controls separate, while the factory unit does not.
Factory sub: https://www.dynamicsounds.co.uk/image/cata...-image.jpg Aftermarket Alpine: https://www.dynamicsounds.co.uk/image/cata...1200-1.jpg Aftermarket Alpine sub mounted on to a non-sub cubby that is mounted a few inches rearward due to the parking-heater box underneath: Click image to enlarge EDIT: edited several times trying to get pictures correct... Roaming around 🇳🇴🇨🇠|
24th Oct 2022 4:15pm |
Thanks Angus_Beef, that's definitely worth knowing. Thanks to the tip on how to spot one from Oldowner I have found one, just waiting for confirmation it's still available!
Using the slimmer version and sub cubby would be a good combo |
25th Oct 2022 6:12am |
