Home > In Car Electronics > Fuel pump electrical connector (Range Rover p38 pump)
Hufflepuff
Can we play a brief game of 'guess the connector' again please, which some of you seem to excel at.
I need to obtain the plug which fits onto the fuel pump for my 110 v8, which I was instructed to base around the p38 Range Rover - so that is the pump I subsequently obtained:
Its some sort of 4 pin arrangement, 2 for the float, and 2 for the pump itself.
Thanks in advance! 2005 Td5 90 XS
1989 V8 110 CSW
Post #967932 16th Oct 2022 7:36pm
Martin
Site Admin
FYI - having to press the photos to get them to open (hosted on HTTP server not HTTPS).
The P38 docs I have show the pump to have a different connector to that. What's the pump part number?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #967940 16th Oct 2022 7:58pm
rallysteve
Looks a lot like a male Econoseal J housing
Post #967941 16th Oct 2022 8:02pm
Hufflepuff
Hmm good question on the part number. When I had the tank made, they (I think Safari Equip - ordered through Brendan at Overland 4x4) bought the pump themselves to make the tank fit around it. Subsequently I never got a retail box - Brendan did say it was a pump for a P38 though.
I will also look into a make Econoseal J housing, thanks Steve.
Martin: thanks for the heads up on the images. I am not sure how to enable HTTPS capabilities on my hosted domain but I will look into it. 2005 Td5 90 XS
1989 V8 110 CSW
Post #967956 16th Oct 2022 9:25pm
Martin
Site Admin
Ah it might be Econoseal, I was looking at it wrong and thought it had an offset rib/key.
Turning my head through 90deg it might well be Econoseal.
I’ve got some 4 way female plugs somewhere.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #967957 16th Oct 2022 9:27pm
Hufflepuff
Although this is a BMW engined diesel p38, I think the pump design looks similar as does the connector.
Timestamps 11:32 and 12:35 is where he is messing about with the plug.
https://youtu.be/Jmp7guuJ6UA?t=689 2005 Td5 90 XS
1989 V8 110 CSW
Post #967959 16th Oct 2022 9:40pm
PaulMc
An Econoseal III 070, 4-way female, fits this pump/sender unit -
https://www.polevolt.co.uk/acatalog/4w-Eco...tml#SID=57
. Paul.
Post #968020 17th Oct 2022 12:34pm
Hufflepuff
Awesome thanks Paul - I'll get that ordered! 2005 Td5 90 XS
1989 V8 110 CSW
Post #968021 17th Oct 2022 12:37pm
