Home > For Sale & Wanted > [For Sale] Mostly Auto-Electrical Items |
rockster57 Member Since: 15 Nov 2014 Location: West Yorkshire Posts: 937 |
Miscellaneous auto-electrical components and Defender spares. All in new/unused condition. Product links shown where I’ve been able to find them.
The attached photos are the actual items offered. Postage will be £2.85 (Royal Mail 2nd Class) for each item unless multiple items required, in which case I will combine postage and let you have the saving. MTA RB4U.1 4-way Relay Mount Box (no relays). I have 2 of these. £10 each. https://www.vehiclewiringproducts.co.uk/p-652-4-way-relay-box Click image to enlarge Click image to enlarge Click image to enlarge SOLD - 12-way RIPCA fusebox 390078 £15 https://www.4x4overlander.com/product/12-w...DoQAvD_BwE Click image to enlarge Click image to enlarge Click image to enlarge SOLD - Labcraft s19 Scenelite (4 available) £15 each https://lightbaruk.co.uk/products/labcraft...lwQAvD_BwE Click image to enlarge Click image to enlarge Click image to enlarge SOLD - Original Lucas Classic Indicator/Horn/Dip Beam switch assembly. Land Rover part number XPB101290LUCAS £15 https://www.lrworkshop.com/parts/XPB101290 Click image to enlarge Click image to enlarge SOLD - Bearmach rear worklight switch and connectors. Fits in place of a blank (or existing switch) in the dash £15 Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Fuel Filter Shielding- Rear WJU500280 (2007-2016 Puma models). There is no part number stamped in this component so I’m assuming it’s a pattern part. £15 https://www.lrworkshop.com/parts/WJU500280 Click image to enlarge Click image to enlarge SOLD - Bonnet Latch (with nipple for release cable). STC925. Genuine JLR part which will cost you around £100 from your friendly local dealer. £10 https://www.lrworkshop.com/parts/STC925 Click image to enlarge SOLD - Misc prop shaft related items, consisting of:- 17-off (ie. full set + 1) of ⅜” UNF bolts and nuts. New Genuine TVK500490 angled grease nipples (2-off) New Genuine FS112306P M12x30mm prop shaft drive flange bolt (2-off) New Bearmach FTC5258G Diff Unit Oil Seal (2-off) New Bearmach FTC5317 Diff Unit Mud Shield (2-off) New Britpart 571752 Axle Shaft Drive Member gaskets (8-off) ½” square drive Prop Shaft Tool (Like new) £20 Click image to enlarge SOLD - Misc Clips/Connectors/Fasteners £5 Click image to enlarge Last edited by rockster57 on 18th Oct 2022 1:28pm. Edited 6 times in total |
16th Oct 2022 3:56pm |
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1845 |
Hi there,
I’ll send a quick PM right now,but I’d happily take the bottom three # two “misc” + bonnet latch, and the horn/lighting switch. Thanks Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
16th Oct 2022 4:03pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2107 |
Flippin’ ‘eck Dean - that was exactly the same list I was going to post - too slow!
16th Oct 2022 5:14pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2237 |
Can i take the bonnet latch and the misc connectors/bits please
Doh too slow again.... Will need postage please Cheers Steve 02' 110 TD5 Double Cab Rebuild Thread |
16th Oct 2022 5:36pm |
Donald, your PM replied to |
16th Oct 2022 5:38pm |
Dean, you PM replied to |
16th Oct 2022 5:57pm |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1146 |
Looking for the work light switch and been disappointed ?
Stock on eBay BUT twice the price !! eBay Item No. 233085133241 Only trying to help someone out there |
16th Oct 2022 6:18pm |
"Stock on eBay BUT twice the price !! "
I have a bit of a reputation around town of being "cheap". I wonder if this is what people have been meaning? |
16th Oct 2022 6:44pm |
Goldenballs Member Since: 22 Apr 2021 Location: Reading Posts: 64 |
Voltmeter please if still available
17th Oct 2022 8:57am |
"Voltmeter please if still available Smile"
Yes, indeed GB. I have PM'd you. Peter |
17th Oct 2022 9:22am |
Bump....
Items remaining:- Relay Mount Boxes Fuel Filter rear guard plate |
18th Oct 2022 1:30pm |
Thanks Rockster - got my items yesterday and very happy. Hope someone takes the other bits off your hands. Donald
22nd Oct 2022 10:04am |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2117 |
Is the fuel filter shield the bit that actually covers the fuel filter and not just the mounting plate on the back ? It’s the front cover part that I am after as I have the rear plate fitted ..
if it is the complete unit with the back and front parts, then I’d like it please ... Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
22nd Oct 2022 2:01pm |
That’s great. Thank you for letting me know. |
23rd Oct 2022 1:49pm |
