Home > Maintenance & Modifications > Inlet manifold cleaning sprays, any good?
Co1
Do these things actually work or are they a waste of money?
Col
Post #965883 24th Sep 2022 4:38pm
Dinnu
Probably they do if they are solvents, but I would not want the crap to be ingested by the engine. Very easy to scratch a bore I think. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #965892 24th Sep 2022 5:32pm
Co1
Was thinking the same, not really sure I want all that crud going into the cylinders.
Post #965904 24th Sep 2022 7:17pm
Years ago, there used to be a product called 10K Boost - it might still be available, I guess - that you'd spray into the turbo, and it would produce huge clouds of white smoke. It made a big difference in the 300tdi engine but I've no idea whether that sort of thing is a good idea for a modern diesel.
 Darren
Post #965914 24th Sep 2022 7:50pm
bear100
By far the best I have come across and is actually the cheapest out there!
Wurth have their own brake cleaner, it’s a byproduct of jet fuel manufacturing I believe? But it’s so good with anything oily of greasy, it dries really quick, leaves no residue and only £2.50 for a litre bottle!
I cleaned mine last weekend and changed the glow plugs.
I also changed the rubber gaskets 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #965922 24th Sep 2022 8:32pm
geobloke
10k Diesel was fabulous Thumbs Up Used it on many TDi Land Rovers and it was incredible at removing oily residue and caked on deposits from the intake. Made such a difference to an engine that wasn't tinkered with. Great stuff. Suspect it has been banned now due to the billowing smoke Rolling with laughter
Post #965938 25th Sep 2022 9:17am
geobloke
Col
Yes they do work, but they are not a cure-all. As said above I have used 10K diesel and a heap of others after that became unavailable. The last was Lucas diesel egr and turbo cleaner (below) on our 2008 Freelander 2. After replacing the timing belt and intake hoses with silicone items (two original items had split) I noticed there was a decent amount of oily residue in the system so figured that it was likely that the EGR valve and VGT turbo were unlikely to be working as freely as they should be. Gave this Lucas product a go and blow me what a difference it made...
Phoebe's turbo is definitely working as it should do and she positively shifts like the proverbial goo off a very shiny shovel...
Does make me want a VGT on Miffy though Rolling Eyes
https://www.amazon.co.uk/gp/product/B0785M...&psc=1
Post #965945 25th Sep 2022 1:16pm
Co1
Cheers Geobloke. Where did you spray it, after the intercooler?
Post #965946 25th Sep 2022 2:22pm
geobloke
That lucas spray is supposed to be post turbo. On The Freelander2 I sprayed it in to the inlet manifold.
The 10k Diesel you could spray in to the turbo. As it happens I found someone on eBay selling the stuff a while back, must be new old stock...
https://www.ebay.co.uk/itm/324315838419?ha...BM_o6I0-5g
Post #965949 25th Sep 2022 3:10pm
Co1
Nice one, thanks.
Post #965955 25th Sep 2022 5:14pm
geobloke
Welcome Co1 Thumbs Up
Post #965961 25th Sep 2022 5:52pm
