![]() | Home > Puma (Tdci) > Cruise Control |
wyvern Member Since: 14 Dec 2009 Location: Cornwall Posts: 2124 ![]() ![]() ![]() |
Looks a good job -been on my to do list for ages !
May I ask which kit you used and is there a link ? Many thanks ![]() Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
Nicely done!
![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Racedriver Member Since: 24 Jan 2019 Location: Buckinghamshire Posts: 118 ![]() ![]() ![]() |
Website is www.canm8.com
Iktank Member Since: 08 Nov 2014 Location: Porthcawl Posts: 237 ![]() ![]() ![]() |
Tidy
Been meaning to fit CC to mine, can you confirm if the control arm for the model you fitted can be located on the RHS of the steering column Cheers |
The control arm for this system would be upside down if fitted on the right side but would still operate correctly. I did originally want it on the right but other kits are alot more money and now it is done I think it is neater and less in the way on the left. Good luck.
Just fitted the same one to our 2012 110 and am very happy so far!
However I did find there are 4 red/black cables - so trial and error before finding the right one ! and note that the accelerator peddle has no captive nuts on so you need to have a spanner on both sides to remove. Apart from that it was all with in my limited capabilities ![]() Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
lolo Member Since: 18 Jul 2021 Location: Vaud Posts: 123 ![]() ![]() ![]() |
Oh that looks cool. That's definitely a feature that I was missing during my last trip. Thank you for the share
![]() Any drilling involved during setup process? Where/how the arm is fixed to the steering column? |
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 391 ![]() ![]() ![]() |
Nice job
The only drilling was for one hole on the Left side of the steering wheel into the top part of the cover. Just take some time to ensure that the position does not foul the indicator/main beam stork or touch the dash .. The cruse control arm has a hollow shaft and bolts on the column cover, its got a variable rotational adjustment and the tip can be swivelled around before securing into its final position ![]() Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
