![]() | Home > Td5 > Under-dash (aircon) fan lost speed I and II, III still ok |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 335 ![]() ![]() ![]() |
Sounds highly likely that the resistors have gone on the blower motor. Only on speed 3 does the full current flow from the motor to the switch, in positions 1 and 2 current flows via resistors and hence the lower speeds. I'm not sure for certain but I think the resistors are nestled nice and tight on the motor in the passenger footwell, really hard to get to. The part number you need is JGM100130, item 5 in the pic below
Good luck! ![]() Click image to enlarge ![]() ![]() Click image to enlarge |
RoadForce Member Since: 17 Jul 2014 Location: Holland Posts: 344 ![]() ![]() ![]() |
thanks a lot for th einfo, but
I just had a good rummage in the footwell of mine...impossible to get to, the unit will have to come out I'm afraid.
Of course it has to
![]() Nothing is ever easy, is it? Thanks for the info though, much appreciated and I learned something new today about how heater fans work ![]() |
Me too! I thought LR would do it the easy way and fit the resistors in the switch which is easy to get to, but oh no...they thought better!
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17699 ![]() ![]() ![]() |
The resistors get hot so are placed near the fan for a bit of cooling.
You'd have thought there was enough cooled, ducted air in that system that the resistors could be placed somewhere more convenient. Just below my left knee would be a perfect spot, consistently at or around 10 degrees C!
I'm not sure the designers did "convenience"! In fact I'm not sure "thought" was.involved in the design process.
