Home > Puma (Tdci) > Fog lamp not working after headlight fault. |
TamarBlue11 Member Since: 25 Sep 2020 Location: England Posts: 226 |
Have you got a multimeter to check voltage at the fog light end is OK?
5th Sep 2022 5:02pm |
colinmcclelland Member Since: 20 Mar 2017 Location: Derry~Londonderry Posts: 2 |
TamarBlue11 yeah had 10.54 coming to the rear fog lamp. I used sandpaper inside the bulb housing and replaced the bulb still nothing. But good news! I then replaced the whole thing with an old one of my dads and it’s working again. Might’ve been corrosion or a loose connection in the fog light bulb housing but I could take it apart to see without breaking it. Thanks for replying so quick and for the suggestion.
5th Sep 2022 8:54pm |
