Home > Puma (Tdci) > Intermittent clutch issue |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17443 |
Most likely to be a problem with the release mechanism, possibly an air bubble in the hydraulics or a failing seal.
Are you losing fluid? |
31st Aug 2022 6:27pm |
Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 578 |
Not loosing fluid that was my first point of investigation
31st Aug 2022 6:35pm |
I’ll look at bleeding it this weekend and also check the locknut on the pushrod. A dealer messed with it years ago when it had the output shaft and clutch replaced under warranty. Wouldn’t surprise me if that was loose too.
31st Aug 2022 6:41pm |
Big Harold Member Since: 09 Jul 2018 Location: nsw Posts: 71 |
When the slave cylinder fails on a Puma there is usually no fluid loss.
It just fails to release. Gearbox out job unfortunately. Mark |
31st Aug 2022 10:38pm |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 |
[quote="Siwynne"]Whilst driving I am getting an issue appear. The clutch doesn’t fully disengage and all gears become difficult to select. There is a slight drag when sat still dragging the truck forward ever so slightly. This will disappear and reappear with no obvious cause other than temperature (possibly). If it was that the clutch was worn I would expect slip not drag.
I drives fine 95% of the time Does sound like a clutch slave cylinder issue, if it’s failing it will progressively get worse. Ride like you stole it!! If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
1st Sep 2022 3:18am |
Thanks for the responses.
Mostly confirming my fears. It is typical that as I work in education and have had six weeks off for summer hols that on the day I return to work this rears it head. I will hopefully limp until October half term and then change the slave cylinder. In the mean time I will bleed it and cross my fingers. If it fails it will at least fail engaged and I will be able to drive it home |
1st Sep 2022 6:19pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20444 |
Dare I say it I think you are a little optimistic that it’ll last unfortunately.
I had the same thing this year, it’ll get worse more rapidly than you realise. You may squeeze 60 miles out if you are lucky but it’ll get worse and worse and will result in you not being able to select a gear randomly wherever you may be and might be dangerous in that situation. It seems surprisingly common for the earlier slaves to fail, this was the problem I had last time as well and fails before the clutch it’s self. This time round I’ve gone for the later LR 2.2 Slave, valve and adaptor which will fit the 2.4 if you have all three parts. If you have the 2.2 then of course those parts fit anyway as standard. But I do feel the earlier slaves did have issues. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
1st Sep 2022 7:41pm |
This reoccurred yesterday. I had driven about 40 miles motorway parked up for about 1 1/2 hours and then drove stop start for about 8 miles. Then it slowly got worse. Changing gear got stiffer and it was dragging when sat at traffic lights. However once in gear and moving if I moved the clutch pedal an inch it would slip as it was disengaging as normal.
I am now suspecting that part of the release mechanism is loose and moving around or a spring is out of place somehow. Driven anther 60 miles today in two 30 mile journeys without issue |
7th Sep 2022 5:33pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4704 |
Was she serviced recently? If gearbox fluid was changed and the incorrect fluid used this could be an issue. 1982 88" 2.25 diesel
7th Sep 2022 5:52pm |
Mmm. All fluids changed recently but only after this had started to happen. I changed the gbox oil thinking it might help. What came out was clean and debris free. I was very careful selecting correct oils and filling the correct volumes
I do think if I can get to the end of October (1/2 term week off) I’ll open it up and have a look and change what needs changing |
7th Sep 2022 6:43pm |
Typical culprits are a spring has came out or partially out of the friction plate due to getting weak or the concentric slave bearing has gone with a hydraulic leak.
If memory serves me rightly the last time I had issues with mine, it was a pinhole leak in the slave diaphragm. So it was leaking clutch fluid inside the box but you would never know and was of course losing pressure in the process but it was a small amount which meant it wasn’t leaking so much that the fluid would disappear quickly. In effect it would happen when warmed up and the small fluid loss was difficult to notice. Funny enough mines in the garage now again being looked at this coming week, I’m pretty sure that the slave is leaking again or a spring has came out too possibly both. Same symptoms as you have described, tried replacing the master cylinder which was a good thing to replace anyway with mine due to age, bled again, etc etc but it didn’t solve it so got to be the slave. I guess the clutch over fingers can get bent too, but isn’t quite as common the slave fog in is more common than actually wearing a clutch out. I’ve never actually worn a clutch out it’s been slave failure each time, but was the earlier slave PN which is why I’ve gone for the 2.2 slave this time. Wasn’t there some discussion about some defects on the earlier clutch slaves, I thought I read something about that once? No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
7th Sep 2022 9:03pm |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2117 |
This sounds like what happened to mine - I thought that the springs had become loose and arranged for a LOF clutch to be fitted, but on removing it proved to be the Spigot Bearing failure which explained why the clutch was quite and that it worked fine when needed.
The clutch was in good order when removed and had no wear after 4 yrs of use The LOF kit included all the parts and was soon sorted. Click image to enlarge Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
8th Sep 2022 6:52am |
That’s interesting, it would be interesting to put up a poll to find out what the most common culprits of failure is.
8th Sep 2022 1:53pm |
Bled it today and ran about a pint and a half through until it ran clear. It was really dark. i hope it has an effect on my problem but I am suspecting the concentric slave cylinder or spigot beating. Mine has had both replaced since new. It is a 2.2 but had the newer clutch, cylinder and bleed arrangement put on at 38k with a new output shaft Now on 121k so a failure could be imminent
11th Sep 2022 7:41pm |
