Home > Maintenance & Modifications > Wheel carrier & alloy wheel
TC909
I've got a 18" alloy to fit as a spare, just wondering if anyone has used a VPLDR0130 wheel carrier with an alloy & especially an 18"? Ads state its for 16" steels only.
Or maybe there's some recommendation of which wheel carrier to use?
Thanks
Post #963199 28th Aug 2022 8:34pm
Ianh
Worth checking out ORE https://ore4x4.co.uk/shop/land-rover-defen...l-carrier/. Well thought of on here, but worth a call to see if 18” Alloys will be ok with their carriers.
Noting that they can support big heavy 285/75r16 MT tyre setups that are circa 33 inch in diameter so I can’t think why they would have an issue with an 18 inch wheel tyre combo.
Post #963207 28th Aug 2022 9:36pm
TC909
Thanks, I did see that one £700 though.... Shocked
Post #963236 29th Aug 2022 9:43am
Ianh
Yep, about twice the price of the std one you highlighted , so not cheap but avoids any drilling and is designed to take significant weight and large wheel/ tyre setups. If you depreciate it over 10 years that extra £350 is only 67 pence per week Very Happy that’s how I convince myself to go for quality products that cost more than standard Rolling with laughter
Post #963240 29th Aug 2022 10:35am
Ianh
A member is advertising a spare wheel carrier on here https://www.defender2.net/forum/topic84567.html
Post #963305 29th Aug 2022 8:11pm
The Zee
United Kingdom 2014 Defender 110 Puma 2.2 USW Indus Silver
Second vote for ORE - Awesome bit of kit, so worth the money, even if its for peace of mind to prevent the rear door from stress cracking in the corners due to the normal boost alloy and tyre combo.
Have a word with Chris McC hes on this forum as chrismack85 or via this topic about wheel carriers : https://www.defender2.net/forum/topic84063.html Zaid-M
www.DefencePhotos.com
2014 Defender 110 Utility, 2.2 Puma, Indus Silver
Not just transport more like a religion
Post #963308 29th Aug 2022 8:44pm
Re: Wheel carrier & alloy wheel
Thanks
There's no technical reason why that carrier shouldn't work with 18" wheels. Going smaller may be an issue but bigger just means that there's more clearance behind the wheel. Darren
Post #963333 30th Aug 2022 9:29am
