Home > Maintenance & Modifications > Dual battery woes
bear100
Dual battery woes
Hi chaps
Currently sat under the foxwing in Barcelona on a Pyrenees expedition, it’s been a warm day here and it looks like my Optima yellow is failing, it’s only 2 years old and after lots of reading Optimas have seriously dropped in quality and many are having the same issues.
I have a national Luna split charge kit and a Gwyn Lewis dual battery tray.
I am not a fan of the national Luna anymore, the controller has a pathetic flimsy hit and miss plug connection, and on occasions because the connection is so poor is not told the solenoid to open and charge, then you use the override button that only lasts for 5 mins.
So enough is enough! What is the best battery’s to use and what split charge kit?
I do like to see and monitor the voltages.
What about DC to DC? 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #961934 16th Aug 2022 8:34pm
jst
I have a national luma In my 110, as you say connectors not good.
For my 130 build I used a blue sea setup. I picked it up 2nd hand. It has manual override but no voltage display. To provide this I just fitted USB chargers that had voltage readings. One on main batt and several on the leisure batt.
Battery wise I run numax leisure batts for both starting and aux. Cvx 27s or 31s. Aboyne £80 each. Have had them 9n 110 for ten years. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #961944 16th Aug 2022 10:03pm
Mungopark
United Kingdom 2000 Defender 110 Td5 CSW Epsom Green
We run a NL system and had exactly the same scenario, with a Yellow top giving up after two years. I have replaced both batteries with an 80 and 100ah Enduroline batteries and I am persevering with the NL system for now. I was looking very closely at a Victron DC DC charger and running one of their bluetooth shunts to monitor draw (currently use a cheap/homemade one off ebay).
Andrew st Pierre white has 'strong' opinions on the drawbacks of solenoid split charging and merits of DC DC, principally Solenoid not achieving quite enough voltage to get a battery to 100%, which DC DC can provide. Although this seems to be a matter of debate across the tinterwebs.
Post #961953 17th Aug 2022 7:45am
bear100
Thanks guys
The more l look the more Optima negative I see and the more DC DC is mentioned.
I don’t know anything about DC charging, you mention mungopark a Bluetooth shunt is this an app that displays the vitals etc? 2016 Range Rover Autobiography 4.4 TDV8
Post #961976 17th Aug 2022 10:25am
bear100
By the looks of it an Orion Victron non isolated charger is ok to use with a non smart alternator, so this will open to allow the alternator to charge the aux battery and act as a charger too? 2016 Range Rover Autobiography 4.4 TDV8
Post #961977 17th Aug 2022 10:35am
Jerry
2015 Defender 110 Puma 2.2 Adventure Phoenix Orange
Have lithiums come down in price yet to be viable?
Post #961978 17th Aug 2022 10:43am
Bluest
If you are using a standard split charge system (not dc/dc) you’d be better not using an AGM battery of any sort I reckon, instead use 2 matched wet cell dual purpose battery like the old favourite Varta LFD90 or it’s newer EFB replacement. I think Yuasa do them too. My reasoning for this is that an AGM has different charging requirements that I don’t think the Defender Alternator is designed for, so AGM never gets properly charged, resulting in not getting full capacity and a shortened life. A Dc/dc system can potentially help here, but it adds a lot of cost and the chargers themselves are quite bulky. I wouldn’t use an AGM as a starter battery at all, just unnecessary expense for no gain.
As a side note, a lot of car manufacturers moved to AGM starter batteries when stop/start systems came in as the battery gets discharged and cycled far more than in a regular car. There have been a lot of problems with batteries failing early and they are now switching to wet cell efb batteries instead as they are more robust. 2007 110 TDCi Station Wagon XS
Post #961982 17th Aug 2022 11:01am
piechipsandpeas
Australia 2013 Defender 110 Puma 2.2 SW Indus Silver
I also have a yellow top optima as a second (under seat) battery and Traxide DT90 dual battery twin isolator. No issues with the Optima after 3 1/2 years.
Traxide are very well regarded over here in Australia. Not sure if available from a UK supplier but you can buy from them direct (traxide@traxide.com.au). Looks like their website is undergoing maintenance / upgrade at the moment.
Post #961985 17th Aug 2022 11:17am
macfrank
Re: Dual battery woes
bear100 wrote:
I am not a fan of the national Luna anymore, the controller has a pathetic flimsy hit and miss plug connection, and on occasions because the connection is so poor is not told the solenoid to open and charge, ...
The "controller" doesn't control the solenoid's normal operation. You can unplug the controller and the soleloid will still do its work, i.e. open and close at voltage levels and after 5 mins. delay.
Yes, that plug is garbage, so I have fixed the plug/cable, too.
I've had no problems with it in 6 years, using two similiar lead acid batteries (original Varta and a 100Ah deep cycle gel Ective).
Post #962045 17th Aug 2022 7:19pm
Mo Murphy
I do think Numax batteries offer best bang for your buck so to speak ! I've had several over the last few years, both leisure and starter, and none have really been looked after but all lasted at least 6 or 7 years.
50 Shades of Pennine Grey
Post #962130 18th Aug 2022 1:20pm
Bill1919
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Corris Grey
As Bluest said if you are going to use an AGM it is essential you use a DC-DC controller. I have the original starter battery and an Odyssey AGM with a CTEX controller. Installed two and half years ago no problems so far. 1988 110 csw 2.5Td (19J) (gone)
1992 110 csw Tdi200 (gone)
1995 110 csw Tdi300 (gone)
2015 110 XS csw 2.2 puma
Post #962148 18th Aug 2022 4:43pm
bear100
Ive moved from Barcelona this morning and currently just outside Arén on the Pyrenees, the weather is much cooler here than in Barcelona and now the battery seems to be working a lot better, so the 10c difference has made a big impact!
Lost faith in it though.
As mentioned lithium would be great but still that stretch to far!
Macfrank how did you fix your controller? 2016 Range Rover Autobiography 4.4 TDV8
Post #962180 18th Aug 2022 8:04pm
macfrank
I glued it to the side of the cubby box, but could be anywhere. The cable is secured by a cable tie through a stick-on cable-tie holder (don't know how it's called), around the plug. This takes the strain from the connector. Not perfect but could easily be removed if needed.
I couldn't find a picture where it is clearly visible, but in this earlier picture, before I fixed it, I drew a red line to show you where:
Post #962188 18th Aug 2022 8:42pm
bankz5152
Given that I used my 110 everyday, i just linked my batteries together without any VSR relays or split charge systems. Starter battery monitored off a dash voltmeter, aux off a bluetooth monitor.
Never skipped a beat in 4 years of use.
Battery wise just the largest Ah that would fit from a decent brand. Think I had two 120ah Exide batteries. Instagram @defender_ventures
Empire Tuning - Agent
Post #962189 18th Aug 2022 8:47pm
donmacn
Like Bear100 I had a yellow top give up the ghost at the beginning of our trip this year. We were lucky that we were mainly planning campsites (quieter in the June off-season) so our answer was to buy hook up cables. We have a blue sea VSR system.
But when I began researching solutions the quote above more or less reflects where I got to - considering a DC-DC controller which it seems would give a better charge for AGM batteries and allow a solar panel to be integrated. Or I could just go much simpler and revert to more basic batteries. I feel I've still a lot to learn, as well as more work to do to decide just what our requirements are. Mainly posting here so that I can get thread updates. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #962198 18th Aug 2022 9:34pm
