Home > Maintenance & Modifications > Flippin’ 3 Amigos |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2106 |
Really not sure how…
But those 3 Amigos are no longer with us. Spent a bit of time testing and checking all the fuses, wiring, relays, connectors etc. on the ABS circuit and applied switch/contact cleaner along the way. That ‘might’ have done it OR the new sensor OR the new WABCO modulator valve switch thingy. Who knows? Not really that reassured and they may be back! |
13th Aug 2022 3:32pm |
Los tres amigos estan muertos
17th Aug 2022 3:41pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2244 |
Might have been as simple as a dirty fuse ! Glad it's resolved !
17th Aug 2022 3:54pm |
Thanks Mo - let’s hope so.
The problem with me ‘going over’ so many potential sources of the issue is that I can’t actually accurately identify what it is/was that caused the problem. Equally I don’t really know whether I’ve cured it At least at the moment, it’s definitely less cramped in the driving seat with those three uninvited guests gone |
17th Aug 2022 4:39pm |
Well the law of sods…
Had a great longish period without the 3 amigos. It was the MOT last week…and yes you’ve guessed it…failed because of the 3 amigos (which weren’t illuminated before or at the point of delivery to the MOT station). Sod’s Law? The garage only have basic diagnostic equipment so couldn’t detect a specific fault. They said the brakes were working fine. I haven’t got any diagnostic equipment nor fault reader so for the first time during my ownership, I will need to rely on a local independent. Sadly the local independent garage that has been recommended hasn’t got back to me… I was going to ask if there’s anyone local to me (West Lancs) with a Nanocom or similar who could help but the reality is it looks like it could be the ABS unit ££££££££ Just a thought - is it possible that when I’ve bled the brakes to replace the calipers I should have had the ABS ‘primed’ for want if a better word? I’m desperately looking for faults other than a completely knackered ABS unit. If it is the unit, then I’m sadly going to have to mothball my Defender until funds allow me to sort it. Please note that all the ABS sensors are new and I’ve replaced the shuttle valve thingy. Thanks in advance. |
19th Nov 2022 5:35pm |
Sicastle71 Member Since: 21 Aug 2019 Location: West Lancs Posts: 128 |
Have a nanocomm based on Southport let me know if that’s any good
19th Nov 2022 9:11pm |
Thanks Sicastle - that’d be really helpful.
I’m not far away from Southport. I’ll PM you. Thanks, Will |
19th Nov 2022 10:27pm |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 625 |
Have you changed the shuttle valve switches in ABS modulator? If yes, did you made bypass of the internall connector? Most of time, the problem is not in the switches and connector on their plastic holder, but in the connector on the opposite side, in the ABS modulator body. Simple bypass is the easiest solution. This is typical problem of ABS in Discovery 2. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
20th Nov 2022 5:56am |
Hi MadTom,
Thanks for the input. I’m afraid I only replaced the plastic element that fixes to the ABS module with 3 Allen head bolts. It was an actual pig of a job as I had to do it all via the side vent, and even then I could only just get my Allen key in. The one I removed looked intact so maybe I could carry out the bypass on that and then take a deep breath and change it back. For the price, it may be worth me buying another new one and carrying out the mod. Sicastle has offered to help with diagnostics, so wondered if the fault you describe would show up and if so what would it read as? Thanks again, Will |
20th Nov 2022 8:38am |
Thanks to Sicastle71 for lending a hand and bringing along his Nanocom 👍
Really nice Landy Si👍 An interesting afternoon where we also put some (not all) of the world to rights. Alas we didn’t resolve the issue today as no faults were displayed… We did identify that the ABS pump motor is deceased - which is good to know but worrying in terms of £££££ We also discovered another fault that is related but sadly not the cause. Looks like I need a new ABS unit. Anyone replaced theirs themselves? Can it be done ‘from above’ without removing the wing? Cheers, Will |
26th Nov 2022 7:20pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4216 |
I’ve had mine out and back in but I took the wing off. It takes longer, but I liked having proper access. I replaced the shuttle valve switch, I didn’t do the bypass as I didn’t know at the time, but it’s been fine since.
BTW, I know you’re sorted now, but I’m in East Lancs with a Nanocom if you ever need. 2007 110 TDCi Station Wagon XS |
26th Nov 2022 8:37pm |
No problem with the help and thanks for the tea hope you get sorted asap anytime you need a hand feel free to give us a shout
26th Nov 2022 9:50pm |
Thanks for the info and kind offer Bluest 👍 Did you replace the whole ABS unit or take it out just to replace the shuttle valve switch on the bottom? My pump motor has failed but I understand you can’t simply replace that - a new ABS block is required £££££ Did you disconnect the unions/pipes and have to re-bleed? If so, was it difficult? Cheers, Will |
26th Nov 2022 10:34pm |
Cheers Si - much appreciated 👍 |
26th Nov 2022 10:35pm |
