Home > Technical > White smoke from the exauhst. |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 |
Unburnt fuel is the common cause of white smoke from cold start, it could be many things but I would put an injector flush through to see if it makes any improvement.
My 2011 2.4 Puma did it in the cold winter for a few mins on start up but after adding a fuel flush and continued use Millers fuel additive, it appears to have improved to the extent that I haven’t noticed it for several months. Ride like you stole it!! If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
7th Aug 2022 5:07am |
5a6eeb Member Since: 05 Aug 2022 Location: AbuDhabi Posts: 11 |
Will try it out.
Thanks bud! |
18th Aug 2022 12:46am |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5222 |
also glow plugs starting to fail, can give the clouds out too, or crap quality fuel.
My Dturbo 306 would cough like hell, for some reason, changed the plugs over, serviced it, even shoved some additives in, never did anything. Changed where i was fuelling from and it was night and day Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
18th Aug 2022 4:47am |
After replacing my vgt hybrid turbo with a new one and updating the tune I have, white smoke started to disappear. Before updating the tune there was still white smoke, and when I updated it, the white smoke started to slowly fade away. But till today there is a bit of white but mainly black smoke when i start the car. Also I dont have any center silencers on the car. But when I push the car in fifth gear at night (with the cars headlight beam directed at the back of my car)I see a lot of smoke coming from the Exauhst pipe, but during the day when I push the car I only see a fair to normal amount of black smoke coming from the Exauhst. Could it be that the white smoke isnt as visible during the day?
18th Aug 2022 12:09pm |
