Home > Off Topic > A simple, cheap material for carbon capture, perhaps from ta
spudfan
Ireland
If this works it might stop the demonising of our internal combustion engines
https://phys.org/news/2022-08-simple-cheap...pture.html 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #960672 5th Aug 2022 2:51pm
The Zee
United Kingdom 2014 Defender 110 Puma 2.2 USW Indus Silver
This may have only been tested in the lab with "synthetic flue gas" so my concerns are:
~ the exhaust gas would have to be filtered to prevent blocking of the absorbent (think DPF fitted before the absorbent cartridge)
~the gas stream needs to cooled, as does the exhaust pipe since the absorbent only works between 30-80C - any hotter and it releases the absorbed CO2
~once the absorbent is saturated/full where is it going to be regenerated to (and how is the CO2 going to be stored) (things like a catalytic converter is always active, DPF filters are re-generated to "burn off" the soot cleaning the filter to begin again)
~how much carbon is it going to take to manufacture, service and dispose of both the absorbent and any additives to make this process work
Sorry to be a killjoy but this tech is now in the very low technology readiness levels (https://en.wikipedia.org/wiki/Technology_readiness_level) it may be many years before even demonstrator versions are available. Zaid-M
www.DefencePhotos.com
2014 Defender 110 Utility, 2.2 Puma, Indus Silver
Not just transport more like a religion
Post #960726 5th Aug 2022 7:51pm
