Home > In Car Electronics > Headlights still on warning buzzer
balmybaldwin
United Kingdom 2002 Defender 90 Td5 CSW Buckingham Blue
Hello,
As my defender doesn't have one I want to fit a little buzzer to warn me when I open the door but I've left the lights or side lights on.
I think this is pretty easy. Essentially I'm looking to take a tap off the "Sidelights" +ve feed that is used by the dashboard lights, and for my negative on the buzzer connect to the door switch circuit used for the interior lights that I believe is a switchable earth
So far so good... until my "Quiet 12v Buzzers" arrived from amazon today. First I was expecting something the size of a 5p and what I got was 2" diameter. It scared the dog, my neighbours car alarm is quieter, it hurts my ears!
I've since been looking at options and they all seem to pump out a lot of decibels... so I could perhaps step down to 5v and use a buzzer I know is about the right volume, but would prefer 12v so I don't have a voltage regulator in the mix.
My other thought is if I can get a more classy "bong" noise device, but on searching the net, it keeps showing me nice vases with weed symbols
So as I seem unable to find anything appropriate, I thought I'd ask on here... Is there in fact an oem/replacement buzzer I can get from a more recent model (puma?) or has anyone done this and can point me in the direction of something that wont make my ears bleed if I forget to turn off the lights.
Post #960262 1st Aug 2022 8:46pm
Ianh
https://www.carbuilder.com/uk/lights-left-on-warning-buzzer
A review “I was pleasantly surprised by the noise this "buzzer" makes. I would describe it more as a "two tone chime" than a buzzer.
Easy to wire in and excellent.”
Sounds ( sorry for the pun) just what you need, i.e ignition off, open door and two tone chimes are sounded if lights left on.
Post #960263 1st Aug 2022 9:19pm
Hazza
United Kingdom 1990 Defender 110 Td5 HT Bronze Green
Stick some electrical tape across the hole on the front of the buzzer - might quieten it enough for you. 1990 Defender 110 200TDI Camper - now converted to Td5 power
Post #960397 3rd Aug 2022 8:51am
Mo Murphy
You could put 12v to the door handle, if you leave your lights on and go to get out the door, you're given a 12v shock. This has the advantage of completely customisable audible alarm since you can alert yourself using what sound you feel would be most effective, a scream or perhaps a cheeky expletive !
HTH
50 Shades of Pennine Grey
Post #960399 3rd Aug 2022 9:12am
Balvaig
Scotland 2016 Defender 90 Puma 2.2 Landmark LE Corris Grey
My 2015 XS has a warning chime when the headlights are on and the door is opened.
According to the workshop manual, from 2012 models onwards have a warning sound .
I cannot find how this is achieved in the workshop manual despite several searches.
You might want to try the circuit diagrams for the 2012 model onwards if you can access them.
Post #960403 3rd Aug 2022 9:50am
Hmm, not present on my 13MY. Darren
Post #960405 3rd Aug 2022 9:59am
Martin
Site Admin
2015MY and 2016MY only.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #960407 3rd Aug 2022 10:44am
matchap801
United Kingdom 2009 Defender 90 Puma 2.4 CSW Zermatt Silver
I followed the lights on relay buzzer guide here - https://www.12voltplanet.co.uk/relay-guide.html
I fitted a pin switch through the side of the seat box in contact with the drivers door. Works a treat as wired through the side lights. 2009 Defender 90 CSW 2.4 TDCI.
Ex Army Mechanic still living the dream.
Post #960467 3rd Aug 2022 9:25pm
Gasket
I didn't know that this was a feature on later Pumas and would love to retrofit to my 2010MY.
Nice to learn something new - would be great if a retrofit loom was available (hint hint Martin Very Happy . My subwoofer loom arrived by the way and as always its a lovely bit of kit)
Post #960500 4th Aug 2022 10:43am
Gasket
duplicate post
Post #960501 4th Aug 2022 10:48am
